Volks AutosMonster Motorsport
Results 1 to 10 of 10
    rokape's Avatar
    Jun 2012
    Cornwall
    77
    Question How to remove gearstick trim?
    Hi,
    I want to change my aluminium trim on my A3, seems to of got corroded / veined somehow from the previous owner. I will get a new one from Audi, but I can't work out how to remove it.
    Done some searching, found these:
    1. How do you remove trim from gear stick?
    2. Fourtitude.com - DIY: Shift Knob Switch (Pics)
    Only, I can't work out how to change just the trim? I don't want to change the gear stick.. any ideas?
    I have managed to get the trim up, but ending up like this: http://img.photobucket.com/albums/v3...i/SV300078.jpg
    Any thoughts?
    Thanks!
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    There is a metal butterfly style clip which clamps the cover on to the gear knob and stick. Cut it off!
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
    rokape's Avatar
    Jun 2012
    Cornwall
    77
    Thanks, I presume you mean this clip? http://img.photobucket.com/albums/v3.../Audi/ring.jpg and http://img.photobucket.com/albums/v3...i/SV300079.jpg ?
    If so, can I just use a cable tie to replace it with? Does a new trim come with a new clip? Only want new trim, not knob too.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Yep thats the one. Im not sure if a cable tie would suffice as the metal ring clamps the blue plastic on to the gear stick. You may be able to get a part number off the ring. Alternatively you can get them in any decent motor factors/DIY store (the rings are used for clamping hoses on)
    For Sale -
    A3 air vents
    rokape's Avatar
    Jun 2012
    Cornwall
    77
    Cool thanks man! I know what you mean now, the ones you tighten with a screw driver?
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Nope, not jubilee clips. I think they would foul the cover.
    Im talking about this style clip...
    You just nip the two "sticky outty" bits with side cutters to tighten. Let me know if you have any bother sourcing one and il post one over to you!
    For Sale -
    A3 air vents
    rokape's Avatar
    Jun 2012
    Cornwall
    77
    Ok awesome. Thanks!
    I presume it's ok to remove it before I get the clip? Ie I just shouldn't pull it up else it will fall off? Or does the clip prevent it from falling down too?
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Prevents it from twisting in your hand too. I replaced mine with a cable tie and its fine. Just pulled it up nice and tight.
    Jul 2011
    105
    +1 for the cable tie. I've been using one without issues for a few years.
    rokape's Avatar
    Jun 2012
    Cornwall
    77
    I took it off & got it ready for a new one. I cable tied it, think they were weak ties or not tight enough.. anyway I decided to use a jubilee clip, works perfectly & really tight!
    Got to source a new trim / boot now.
  1. How to remove A3 boot trim - with photos
    By Fleagle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2013, 22:36
  2. how to remove windscreen trim ?
    By white.akita in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th November 2011, 19:43
  3. How to remove dash trim?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2009, 21:36
  4. How to remove trim panel under steering wheel?
    By Lovegroover in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2006, 10:35
  5. how to removing interior trim and replace with s-line alu trim??
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2006, 01:21
Tags for this Thread
