Sky InsuranceChris Nott
    Jan 2012
    London
    35
    A3 Rear Parking Sensors - No Drill Points on Inside of Bumper
    HELP !
    I have just taken off my A3's rear bumper and there are no crosses or points where the rear parking sensors are meant to fit.
    I purchased a aftermarket kit and I was under the impression the drill points are marked on the inside of the bumper but the are not.
    My car is a currently in bits and the bumper is on the table so a rapid response would be very much appreciated.
    Thanks in advance.
    Regards
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,147
    You don't say which model you have, but my original 08 3 door bumper definitely has the markings as I've just looked!
    E93 335i
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    Jan 2012
    London
    35
    2004 8p 3 door
    26,762
    Then just drill some holes based on measurements taken from a car with them.
    Mar 2011
    30
    Aftermarket Parking Sensor reverse light feed question
    Sensors are positioned as the factory which are 30mm center down from bumper leading edge, 240mm either side of center line from boot catch and then 430mm center to center from inner sensor
    26,762
    I seem to recall those roundabout measurements from my fitments, so use a marker pen that can be wiped of if incorrect & then look at from distance to see if they look ok.
  1. Something is up with my rear parking sensors???
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2005, 16:32
  2. Anybody got rear parking sensors?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2005, 11:26
  3. Retro-fit rear parking sensors
    Last Post: 11th February 2005, 23:47
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
