Hi,
I have just acquired a VCDS of a friend and I have plugged it into my 2004 A3 3 door.
I cleared the errors but after a 20 min drive and good proportion of them came back.
A couple of months ago, I retrofitted a RNS-E with Bluetooth and had it coded by a Audi Sport member.
Below is the log from VCDS
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 77
VIN: WAUZZZ8P24A040919 Mileage: 188090km/116873miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 BB
Component: SIMOS71 1.6l 2V 5312
Revision: 00000003 Serial number: AUX7Z0C6FN4020
Coding: 0000071
Shop #: WSC 06435 000 00000
VCID: 60CBA4B3CAD3
3 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 006 - Short to Plus - Intermittent
Freeze Frame:
Temperature: 57.0∞C
Temperature: 57.0∞C
Temperature: 25.5∞C
RPM: 1504 /min
Temperature: 58.5∞C
Temperature: 58.5∞C
Temperature: 25.5∞C
RPM: 2080 /min
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
P1951 - 007 - Short to Ground - Intermittent
Freeze Frame:
RPM: 1792 /min
Temperature: 64.5∞C
Temperature: 28.5∞C
Speed: 48.0 km/h
RPM: 1856 /min
Temperature: 72.0∞C
Temperature: 36.0∞C
Speed: 38.0 km/h
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 006 - Short to Plus
Freeze Frame:
Voltage: 2.000 V
Voltage: 0.160 V
Lambda: 10.5 %
Bin. Bits: 00001000
Voltage: 1.980 V
Voltage: 0.900 V
Lambda: 13.7 %
Bin. Bits: 00001000
Readiness: 0010 1001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0051846
VCID: 33611BFF2BA5
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
VCID: 2B51039FF395
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 52
Reset counter: 107
Mileage: 186876 km
Time Indication: 0
Date: 2012.07.16
Time: 15:46:39
Freeze Frame:
Voltage: 11.90 V
Temperature: 21.5∞C
(no units): 208.0
(no units): 169.0
Temperature: 14.5∞C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000073834
Coding: 018C4F00A0141000000000000000000000
VCID: 3B7133DF03F5
Part No: 8P2 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 458555277531
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenks‰ulenmodul 008 0030
Coding: 0000012
VCID: 306B14F3DAB3
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 E HW: 8P0 920 980 E
Component: KOMBIINSTR. VDO H25 0070
Revision: D04 Serial number: 2246CD04001357
Coding: 0004413
Shop #: WSC 00196 210 06488
VCID: 397D29D709C9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0070
Revision: 08 Serial number: 17001035085505
Coding: 3D0F03CA070101
Shop #: WSC 06435 123 12345
VCID: 2647F2ABE877
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D04 Serial number: AUX7Z0C6FN4020
Shop #: WSC 00196 196 04543
VCID: 397D29D709C9
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H46 X---
Revision: 03S Serial number: AUZBZ7D0001797
Coding: 0215711
VCID: ECD34083B61B
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 106
Mileage: 188034 km
Time Indication: 0
Date: 2012.07.28
Time: 12:44:27
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H09 0010
Coding: 0000048
VCID: 397D29D709C9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.6 0402
VCID: 33611BFF2BA5
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 8000 km
Temperature: 19.0∞C
Voltage: 11.30 V
Voltage: 11.20 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0030
Coding: 188800186D288505485AC63000
VCID: F9FD69D7C949
Component: Sounder No Answer
Component: NGS No Answer
Component: IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001033476
VCID: F0EB54F39A33
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A7F36DB0CCF
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0215711
VCID: ECD34083B61B
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 106
Mileage: 188034 km
Time Indication: 0
Date: 2012.07.28
Time: 12:44:27
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 M HW: 8P0 862 335 M
Component: FSE_255x BT H21 0200
Revision: 00000001 Serial number: 00000000376393
Coding: 0010322
Shop #: WSC 06325 000 00000
VCID: 408B44336A13
Any help would be much appreciated as there does is not alot of information about specific errors on either Ross-Tech or ASN.
