EM TuningAH Fabrications
Results 1 to 20 of 20
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    BKD Noise From Engine Chamber When Stationary
    Hi,
    Recently my car developed a noise when stationary. It sounds like a there was a loose stone in a metal/plastic can.
    The noise comes from the left side of the engine (where the fuel filter is located).
    Video below.
    Can anyone suggest what's wrong?
    Many thanks
    VCDS USER
    Apr 2011
    63
    I had sounds like these one on mine bkd motor recently.Since i changed clutch+flywheel problems solved.Have you ever changed these parts?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Changed clutch and flywheel two years ago.
    VCDS USER
    Apr 2011
    63
    how many miles since then?(if you remember),your local garage opinion
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Only around 20k
    VCDS USER
    Feb 2012
    Birmingham
    132
    Did you find out what this was in the end?? Mine has recently developed this.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    I haven't been driving much lately since my new job and not had time to deal with it.
    Guessing it's the alternator clutch pulley, as the cabin lights are slightly blinking when the engine is running. Around £120 to repair, all incl.
    VCDS USER
    26,747
    Yeah it does seem to be imho related to the belt/pulley area.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Just an update on this thread:
    Replaced alternator clutch pulley with the belt and this cured the problem.
    £110 parts & labour.
    VCDS USER
    26,747
    Changed an aux belt today on a guys car, which had the most horrendous noise as per yours & the noises went straight away, no pulley changed.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Did he have flickering cabin lights when idling?
    VCDS USER
    26,747
    Nope, guess yours did then?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Yes and that is why I also had to replace the alternator clutch pulley. Such a relief to only hear the good old diesel again.
    VCDS USER
    Mar 2012
    52
    I have a similar sound on tickover - upto about 1500rpm. I've always thought it was the engine cover as I have some grommets missing. I've just looked and the tensioner is rattling about a fair bit. The belt leading upto the alternator vibrates but it looks to be off the tensioner. Do you think it's the alternator pulley or tensioner. I've just made a vid if that would help.
    26,747
    Post the vid then.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    The belt will be flapping a bit when it's the alternator clutch pulley, you may also be able to observe cabin lights flickering on tickover.
    VCDS USER
    Mar 2012
    52
    I have a little bit of flicker mainly when I lift the clutch without revs. I sometimes get heavy steering too which I've read could be related too. Another thing I have is a squeak when I start the car which I assumed was the starter. I've read that could also be the clutch pulley too? My vids currently processing on YouTube.
    Mar 2012
    52
    Mar 2012
    52
    Any ideas on this one?
    26,747
    Well if steering is going heavy, light flickers, alternator is definitely one place to check yes, the racks electric so maybe a telling sign.
  1. Squeaking noise from engine when cold.
    By rockape in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2011, 12:38
  2. Help with tick tick noise from engine
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 17:33
  3. Strange S3 noise from engine
    By showyS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2007, 08:09
  4. HELP-ticking noise from engine
    By donnylad in forum Classic Audi Forum
    Last Post: 28th August 2006, 21:08
  5. ticking noise from engine
    By chrisa4quat in forum Tuning
    Last Post: 13th September 2005, 06:34
