Badger5Chris Nott
    Sep 2011
    lancs
    Lightbulb AUDI A3 FRONT PASSENGER SEATS
    Hello all, probably done all this before. my passenger seat wont slide forward with the lever on the seat, had a quick look four torque bolts seat out, had a feel under the seat a bit of black plastic fell down rang audi YES the parts are available£6.53 NOW the question has anyone fitted this plastic thingy before? some say no parts available and its a design fault HELP.
    Thanks very much
    Apr 2012
    16
    Do you mean it doesn't slide forward at all, or does it only move with the lever at the front of the seat base and not with the one on the top of the seat back?
    If it's the one on the back that doesn't make it slide forward ten it's only a £0.60 part. There is a how to in the technical section somewhere. I managed to change it without removing the seat. If you re anywhere near Wrexham I am happy to give you a hand.
    Sep 2011
    lancs
    Cool thanks
    Thanks very much i am in lancs a bit of a run but thank you anyway
    Sep 2011
    lancs
    Sorry forgot to say it IS the one on the back of the seat i am so relieved
    27,126
    Pic of the part would help in giving correct advice, please post up a pic.
  1. Audi A4 Cabriolet 2005 easy entry front passenger seat mechanism broken?
    By carlos19664 in forum General Technical / How To
    Last Post: 22nd October 2013, 20:17
  2. Front passenger seat removal on 3 door S3
    By Roswell in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2011, 23:05
  3. Front Passenger Seat Stuck
    By Pii in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th March 2010, 18:30
  4. HELP front passenger seat probem
    By Ballcrusher in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2008, 07:35
  5. Front passenger seat
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2005, 14:21
