AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    Oct 2011
    9
    project A3, air and speedlines
    Hi all, my name is Jonny. I’m an apprentice for a well-knownaerospace company. I’ve been around on the forums for a while nowbut been quiet and not got a right lot done. My previous car was a mk4anniversary rep. carried out all the work myself
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/SAM_0867.jpg[/IMG]
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/cars/IMG_1818.jpg[/IMG]
    I sold this in November and bought myself an A3 2.0tdi 3 door in grey, withevery intention of doing nothing to it at all… that lasted about 2 weeks J
    firstly was to take the horrible wood trim out. I bought myself a full set ofpiano black trims and played about with vinyl wrapping them.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/IMG_0232.jpg[/IMG]
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/IMG_0151.jpg[/IMG]
    In the end I preferred the standard black.
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/IMG_0150.jpg[/IMG]
    Might look into getting them done in real carbon at somepoint.
    Next thing I did was to de badge and de wiper the rear. Looksso much better
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/098.jpg[/IMG]
    Early February I had a few troubles with the cars electricswhich turned out to be the alternator and the battery so changed both of theseand everything was working a treat again.
    In February I ended up buying a set of 19”speedlines, theirET48 8.5J. Ideally I would have liked a staggered set up with a 9J ET 41 butthat will be for a later date. Until then I’ve bought myself a set of 8mmspacers.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/010.jpg[/IMG]
    The next big purchase I had was air ride in April. I bought a 2 way electric firestone kit.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/041.jpg[/IMG]
    I started with making the gauge mound up. I wanted them tobe as subtle and as OEM as possible and decided that I wanted to mount them inthe ash tray. I haven’t seen anyone else do the same on an 8p. Probably hasbeen done though. Not the easiest ofjobs as it was tight in there and not allot of room to play about with. Apologies for the iPhone pictures
    I bought myself a new ashtray
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/059.jpg[/IMG]
    this is how I wanted it too look
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/060.jpg[/IMG]
    so I took it to pieces
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/061.jpg[/IMG]
    Cut the bottom out
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/062.jpg[/IMG]
    Glued everything into position with a hot glue gun
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/071.jpg[/IMG]
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/cars/070.jpg[/IMG]
    Then used a lot of body filler to smooth everything in
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/072.jpg[/IMG]
    This is as far as I got with the gauges before I needed themto fit the air ride so they need finishing of
    The tank was a bit shabby and had scratches all over it, so Iflatted it down
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/cars/074.jpg[/IMG]
    Re-sprayed in a satin black and mounted in the boot where I wantedit to sit.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/075.jpg[/IMG]
    My spare wheel well was only a space saver so unfortunately itwould fit completely hidden under the floor, so I decided to cut a slot out ofthe floor to show half the tank through
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/076.jpg[/IMG]
    And this is how the boot looked when it was all puttogether.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/083.jpg[/IMG]
    The next problem I faced was the front struts. The kit I hadpurchased was a 50mm strut and I needed a 55mm. (I had realised this before I boughtthem it was just they were so cheap).
    The options I had for this was to go to Rayvern and pay through the nose forsome 55mm struts and mount the bags on them or what I came up with was to gethold of a pair of the 50 – 55mm shims like the ones found on the JOM bluelinecoilover kits and mount them to the struts.
    I picked up a second hand set of the JOM coilovers, took the shims out and soldthe kit on for double what I paid, Result!
    The shims did take a bit of reworking to make them fit. I had to cut backaround 25mm from the top and file the inside radius of the lip on the bottom ofthem to ensure they would go around the strut and close tight when bolted intothe hub. [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/082.jpg[/IMG]
    A bit of effort but worth it for the saving. And this iswhat they looked like fully built up.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/085.jpg[/IMG]
    The next step was to sort the rear mounting plates. The guy Ihad bought them of had mullered the edge that needed welding on to the car withhis welding. It had burnt through the metal in places and he had hacked at themwith an angle grinder to get them off.
    Can’t see very well in the photo
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/081.jpg[/IMG]
    So I cut them off and grinded them back.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/080.jpg[/IMG]
    I couldn’t find any steel that was the same diameter internallyand externally so I had to get a larger piece milled down on a lathe at workbut it worked a treat.
    I hired out a workshop for the weekend to put the kit on. I’m not a mechanic byany stretch but I managed eventually after 2 very long days to get the kit on. Biggestball ache I had was getting the standard struts out of the hub. But after 3hours of hammering and swearing they were out.
    And here’s how it sits for now.
    [IMG]
    http://i824.photobucket.com/albums/zz163/jonnyb289/cars/088.jpg[/IMG]
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/cars/096.jpg[/IMG]
    [IMG]http://i824.photobucket.com/albums/zz163/jonnyb289/cars/093.jpg[/IMG]
    I’m going to play about with how it is for a while just to ironout the problems. Since disconnecting the battery to weld the rear struts theunlock button on my key fob has stopped working? And I can’t get the bags todump (something to do with the wring or plumbing) ill figure it out.
    Hopefully should finishof the gauges this week and the wheels should be on very soon. I’ll get some proper photos with the DSLR then.
    plans for the future are lamin x frontlights (light tint headlights, yellow fogs) LED all lights, sort paintwork out,machine polish, polish / clean exhaust tips and maybe 06 -08 plate slineconversion. I’ll keep you posted.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,128
    All your links don't work.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,320
    Quote Originally Posted by N8 View Post
    grammer young lad!
    None of the links work
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Sep 2009
    Trotters, Peckham
    539
    it's ok N8, I fixed it for ya. Here is what his car looks like
    Dec
    Oct 2009
    Colchester, Essex, United Kingdom
    318
    God this thread was bugging me!
    Cut the bottom out
    '04 A3 2.0 TDI.
    Dec
    Oct 2009
    318
    And the rest:
    '04 A3 2.0 TDI.
    Oct 2011
    9
    thanks alot for that, what had i done wrong with the links?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,128
    Better, Tom, that's my car You whopper!
  1. Fault- Heater warm air and cool
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th August 2010, 20:26
  2. Todays Project, Good Clean and paint Calipers...What do you think?
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd May 2010, 13:43
  3. My A3 Project!! help, advice and your views please guys!
    By Geoff_gc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2010, 16:32
  4. Project Blue Beam and the UFO on 14th Oct 2008
    By Turkster in forum General Chat
    Last Post: 26th August 2008, 20:11
