EM TuningAH Fabrications
Results 1 to 8 of 8
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    Angry Wheel alignment :s
    Had two new rear tyres fitted today to the S3 and drove up the road to find my steering wheel out of alignment and the car pulling to the left. When i taken it back to the garage they test drove it and agreed this was the case. They seemed puzzled why this had happened and said it could be the difference in tread on the front to rear tyres however there isnt much of a discrepancy as the fronts still have a good 6mm left.
    Had 4 wheel alignment carried out today and the cars now set up correctly.
    Heres the results:
    The rear toe was out on both sides, and the offside rear camber was -1.53 previous to the adjustments. Must be tyres?
    But still my wheel isnt centralised when going straight and the car is still pulling to the left. Only thing i can think of is faulty tyres? :s Any input / ideas much appreciated!
    Jun 2012
    Warrington
    37
    Step one of wheel alignment is usually setting your steering wheel to 12 o'clock (straight ahead) and fixing it there, then checking and adjusting the rolling wheels from there, steering wheel should always point straight at the end unless you've a wishbone or track rod end issue, both is which a garage should of spotted? Personally I'd take it back to the alignment place and complain!
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    Yeh ill have to go back tomorrow. I had my MOT only last week also so surely they would have spotted any other issues. Just puzzles me how i drove it to the tyre garage, watched them simply put new tyres on, then drove away with a wonky steering wheel
    antmax7's Avatar
    sheffield
    300
    On the print out front right camber and left rear camber are still boarderline why have they not set them bang on???
    Hope you didn't pay much!
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    Quote Originally Posted by antmax7 View Post
    what should they be like mate? Not clued up on all this alignment stuff haha
    £35 it cost, im going back tomorrow as the steering wheel is still off centre when the cars going straight!
    antmax7's Avatar
    sheffield
    300
    On the print out for each wheel you have two green bars one for camber and one for toe
    You have a black line right in the center of these bars that is where the black arrow should point to. For both camber and toe or very very close to these values.
    antmax7's Avatar
    sheffield
    300
    Sounds like they only made one adjustment if they charged £35
    Have you got the before print out???
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    Yeh i see that now ive had a proper look, hopefully get it all sorted tomorrow, cheers mate.
  1. 200 for wheel alignment?!?
    By imported_shkwav in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2007, 19:10
  2. Wheel alignment in Scotland
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 16:54
  3. Tracking/wheel alignment
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2005, 10:17
  4. AMD Wheel Alignment - Had it done ? Comments please
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2005, 18:57
  5. wheel alignment
    By JayBeeS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2003, 16:57
