AH FabricationsBadger5
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By SCFC_Messiah
Thread: s line lowering advice?? i know a nothing!!
    bjw
    Apr 2012
    6
    Right after just joining and reading some old threads trying to find out about lowering im baffled and would be v gratefull of of all your advice as everyone here seems to know more than me...i have a 56 plate black a3 170 s line i want to lower it with out my teeth dropping out when i drive!! It has 64k on clock is just changing springs ok??
    Mar 2012
    278
    I have the exact same car as you, age and model, and have lowered it on H&R 50mm lowering springs. All I changed was the springs. Aesthetically it looks much better and handling has improved - and although it is a firmer ride it really isn't bone shaking. I'd recommend
    Check out pictures here if interested - Garnet S-Line - Messiahs TDi 170
    Also worth considering spacers if your still on the standard S-Line rims. I went with 12mm on the rears and 10mm on the front
    bjw
    Apr 2012
    6
    Quote Originally Posted by SCFC_Messiah View Post
    Thanks that def looks alot better are they 50 all round?...how many miles had your car done when you had springs fitted?
    bjw
    Apr 2012
    6
    [IMG]IMG_1040[/IMG]
    Mar 2012
    278
    Fairly high miler, 98k. They were only fitted a few weeks ago so can't comment on whether the stiffer ride will add any extra strain to the ageing suspension parts that I didn't upgrade. I read that on an S-Line your safe just changing the springs because the dampers etc. are good enough to cope with the stiffer ride. So I think you'll be ok
    Yep, the 50mm H&R springs only actually drop an S-Line by around 35mm all round. The quoted 50mm drop is based on a sport/se A3 which is around 15mm higher than an S-Line as standard
    The other option you have beside H&Rs are Eibach Sportlines. They drop the car a little less on the rear though, so it gives the car more of a nose down look. Apparently they're a slightly softer ride too
    bjw likes this.
    bjw
    Apr 2012
    6
    I rang a (wont name them) retailer today and they said at 64k id need coilovers so thanks for that as have just bought the car and fitted RNSE CHROME i dont want to spend that kind of £££ just fitting springs would be lot better for me
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by bjw View Post
    They've just given you the generic response of "if your shocks have done more than 50-60k then they'll need to be changed", which isn't true. It depends what condition they are in.
    My car had done over 50k when I had Eibach Sportline springs fitted (50mm/40mm drop, front/rear) and my shocks are still fine almost a year later.
    bjw
    Apr 2012
    6
    Do you have any pics of your car after the drop?sounds like im gonna risk it and just go for springs now tho thanks
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Im just in the process of doing the same as ADS, I ordered some Eibach Sportlines springs from Germany as they only lower the car 5mm if that on the standard S-Line setup. One of my previous cars had Eibach Sportlines on it for over 60K (the shocks were eventually on about 90k) and it was still spot on ride-wise. I think most problems with aftermarket springs seem to occur when they are cheap, rock hard &/or stupidly low so they tend to wear the damper at an accelarated rate.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Plenty of pics here mate, from post #78 ----> My SPORT to S-LINE Conversion (Part No's, Prices & Tips included)...
    Quote Originally Posted by max69vk View Post
    That'll be Eibach Pro springs then. They lower 30mm below standard height, so s-line already being 25mm lower than standard means you only get a 5mm drop. The sportlines will give you a 25mm/15mm drop front/rear on an s-line.
    Mar 2012
    278
    Sportlines will lower an S-Line considerably more than 5mm. You sure you haven't ordered Eibach Pro-Kit springs? They offer a 30mm drop on standard A3s, so around 10-15mm on an S-Line.... Or did you mean to type 5cm?
    Mar 2012
    278
    Quote Originally Posted by Ads View Post
    I was under the impression there's only a 15mm difference between standard an S-Line, not 25mm?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Nah, you're thinking of a Sport. It goes...
    Standard/SE = no drop.
    Sport = 15mm lower than standard.
    S-line = 10mm lower than Sport (which equals a 25mm drop on standard/SE).
    bjw
    Apr 2012
    6
    so 50mm spring will drop it 25mm??
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    On an s-line, that is correct.
    max69vk's Avatar
    Apr 2012
    745
    Just double checked & they're defo Sportlines so it looks like I'm getting more of a drop than expected then. Result
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    You'll be seeing a drop of up to 25mm then.
  1. S-Line lower bumpers for Avant TDI
    By Tanuki in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th January 2007, 17:48
  2. rear bumper S-line lower spoiler panel
    By griffj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2006, 20:31
  3. Lowering advice and these wheels!!!
    By aldo8 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2005, 20:19
  4. Another lowering advice thread.
    By Drysdale in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2005, 14:47
  5. lowering advice please?
    By wright758 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2004, 14:29
