Badger5JMB Retrofits
Results 1 to 9 of 9
Thread: Mapping out EGR
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Mapping out EGR
    There's been a hesitation on my A3 (PD140) that was happening around 1500-2100rpm on part throttle.
    After various attempts to fix the problem, it turns out that by disconnecting the vacuum pipe to the EGR cures the hesitation completely.
    I'm not going to leave the vacuum pipe disconnected as its going to throw an EML up, so i'm going to try a blanking pipe with the hole in the middle like a reducer to restrict exhaust flow back into the system.
    Hopefully this will cure both the hesitation AND prevent an EML, if this doesn't work and I have to completely blank it all off, how do I go about 'mapping' the EGR out?
    I already have an AMD remap and they want £150 to disable the EGR, is it possible with vag-com? And if so, anyone in the south east fancy doing it for me!!?
    27,114
    Has to be mapped out by a tuner, cant be done via vcds & dont blank of at the vacuum end, just stick the metal plate in line of the egr exhaust pipe connection for now to test it more, so the egr still opens & closes until you can afford the map, shouldnt affect the car with the mil on for that afaik for short periods or atall tbh.
    tdi-man's Avatar
    Jul 2009
    1,612
    £150 woow thats alot my mapper mapped it out in the main map and was the same price as mapping it.
    blanking plate is a couple of quid job done.
    or you could remove it and clean it and refit it may cure the probelm .
    Turner race developments south west UK car tuning company
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    27,114
    Thats because they were doing the map at the same time, but doing the egr map on a seperate occasion takes up there time so why shouldnt they charge, common sense prevails.
    Nov 2004
    Tonbridge, Kent
    912
    What Nige said ^^^
    You still need to read the ecu, modify the file and then re-load it.
    27,114
    Quote Originally Posted by W8 Performance View Post
    What Nige said ^^^
    Exactly, with all respect, time isnt free no matter which way you look at it & the reason why people are in business, wish some people would understand that fact, instead of expecting everything for nothing all the time.
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    You could try fitting the smaller gasket from the Ibiza Cupra. This has a smaller diameter then the gasket currently fitted
    PD170 Stuttering Problem Solved [Archive] - SEAT Cupra.net - SEAT Forum
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Dec 2008
    London
    340
    Quote Originally Posted by Rhyso View Post
    Cheers mate, but I've got one of eBay already so I'll give this a go and see how it runs.
    And NHN, I'm not expecting anything for free, I just can't justify £150 to map the EGR out when there
    are potentially much cheaper options...
    27,114
    Quote Originally Posted by rickyquicky View Post
    It wasnt directed at you.
    Let me ask you this, how much time have you honestly spent on the problem, I'd hazard a guess a fair few hours, time = money, so £150 isnt exactly a huge amount if you can afford to map the car in the 1st place :P, but I would try to ascertain what the issue is with the egr system 1st as you may spend the money for the map & still find issues, always best to map egr out on a car that doesnt have existing issues.
  1. Cleaning out Intake Manifold and EGR
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th November 2013, 11:53
  2. Mapping out the MAF sensor?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2011, 17:51
  3. Cleaned out my EGR at the weekend and...
    By RS84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2010, 23:51
  4. Cleaned out intercooler and egr valve today: 146,000 miles.
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th October 2010, 18:48
  5. A4 diesel turbo EGR pipe blew out
    By mickyal in forum Diesel forum
    Last Post: 7th November 2008, 17:42
