Results 1 to 7 of 7
    Sep 2011
    south wales
    114
    2007 A3 2.0 TDi DSG not shifting gears properly
    Hi guys, wonder if any of you can help me with my problem, I've got the 2007 2.0 TDi 140 BKD engine A3.
    Yesterday I was driving along & stopped at a junction, I heard a beep & my ABS & ESP light iluminated on my dash with a message saying fault, see car manual.
    Then I parked up & went into my doctors. Got back in the car & the lights had gone out! Started off fine, but then my car wouldn't shift past 3rd gear unless I redlined itI thought! Today I got in the car lights came back on dash, yet gears were smooth again. This is intermittent, when the ABS & ESP lights are on, gears shift fine, when the lights go out again my car drives as if it's in sport, I'm having to rag it to get it to auto change. Paddles work fine tho, as does the shifter in m mode My car is confused!
    Any Ideas guys?? Pleeeease!
    cheers in advance!
    Aug 2003
    291
    Quote Originally Posted by leecool View Post
    cheers in advance!
    I wouldn't be an expert but it could be the mechatronics unit which is known to give problems.
    When it's warmed up does jerk when taking off in first gear or reversing?
    Also does it shift down to early to second gear when slowing down?
    Sep 2011
    south wales
    114
    Hi, I'm not having jerking probs, just that my car thinks its in sport when in D & It revs its t**s off before changing up. I Can change up & down smoothly with stick & paddles, just not in D auto.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    you need to scan for fault codes
    Jan 2011
    Hi did you find out what the issue was?
    I'm experiencing the exact same behavior with my car a 2006 A3 2.0 TDI BKD with dsg.
    May 2013
    245
    Quote Originally Posted by andri86 View Post
    Have you scanned it for faults? OP hasn't been active for a while..
    Sep 2011
    south wales
    114
    erratic gears on dsg
    Hi there, for me is was a rear speed sensor, it can also be the wheel bearing causing the sensor to react & give false readings. My gears were erratic as hell, as soon as I had the speed sensor done it was sweet.
    The sensors are cheap, but the labour the stealers will charge will take it up over £200.00+. If you know a mechanic who can do it on the cheap, avoid huge un-necessary labour charges.
    Hope you sort it.
  1. Lumpy start & turnover on 2007 A3 2.0ltr tdi dsg sportback s-line
    By leecool in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2011, 15:50
  2. MFSW fitting to 2007 A3 2ltr Tdi Dsg sportback s-line
    Last Post: 15th September 2011, 22:30
  3. Questions to upgrade a new A3 2.0 TDI DSG
    By imported_ilclifford in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2004, 12:53
  4. A3 2.0 TDI DSG S-LINE
    By imported_BAVO in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2004, 00:12
  5. Audi 4000s not shifting
    By Chiwen in forum Classic Audi Forum
    Last Post: 15th November 2003, 18:00
