Thread: Engine Misfire
    Jul 2012
    Engine Misfire
    Hi,
    I have a problem with my 2004 AUDI A3 2.0 FSI. The engine has been misfiring, by this I mean it judders only on start up from cold and after driving for a while there are no apparant problems. It seems to be worse under load (going up a hill).
    I have been to AUDI and they replaced the coil packs for free as they said it was part of some warrantly recall. After they did this it was ok for a few days and then I started getting the misfire again and the emission control light came back on.
    I took it back to AUDI and the diagnostics came back as saying that there 'might' be a problem with the fuel injectors and that the Lambda sensor 'might' need replacing. If they had said they definately know it was the injectors then I would go ahead and get the work done but they want a lot of money to first investigate if it is that and then a load more to replace them.
    Would faulty injectors cause these symptoms?...wouldnt I experience the misfire all the time and not only at start up?
    Would a faulty Lambda sensor cause these symptoms?
    After googling the problem I have tried putting fuel injector/ fuel additive in the petrol but it hasn't helped.
    Jul 2012
    23
    Id do some research before you give them your car, as you might be aware that alot of people have had this recall and have had a shed load of problems after.
    Check out the following link:
    2.0 TDI (BNM) engine sounding rough AFTER injector swap.
  1. 3.2 Engine Misfire
    By stevenbeedie in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 7th March 2012, 14:07
  2. Engine Misfire - Can't access spark plugs
    By silverswish in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2011, 14:19
  3. Light misfire and poor fuel consumption on 2.8 ACK engine
    By ajsphead in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2008, 16:34
  4. Help!! - In dire need of advice... engine misfire
    By Raspeir in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2007, 14:21
  5. Help, engine feels like it's misfiring
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2006, 12:41
