JMB RetrofitsChris Nott
Results 1 to 16 of 16
    Jul 2012
    10
    Drivers side window
    I am having issues with the drivers side window on my A3 Sportback. I can lower it with one press of the button but I cannot raise it the same way. I have to hold it until it is closed. I have tried completely closing it and opening it again several times but it still isn't working. I have a VagCom cable so if I need to do any programming I can. Can anyone offer me any advice?
    Thanks,
    Paul
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Have you tried closing the window fully, releasing the window button, and then pressing it in the close direction again and holding for a few seconds?
    Do the same for opening as well. This should reset it and enable one touch open/close again.
    Jul 2012
    10
    Will go out to the carpark and try it now and report back. Thanks
    Jul 2012
    10
    Just tried it. Unfortunately it still isn't working
    Jul 2012
    10
    Just to add, the passenger and rear windows work perfectly just not the one that I use the most
    Apr 2012
    N. Wales, LL22
    1,224
    is the total closure working on the key?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    You could try disconnecting your battery and reconnecting, and then try the reset procedure again. You will need to do it on all windows though.
    Jul 2012
    10
    Quote Originally Posted by Ste_Nova View Post
    Yes, hold the lock button for a few seconds and all windows close so I don't think there is an issue with the motor.
    Jul 2012
    10
    The car has just had a new cylinder head fitted and the window did not work before or after. I believe the battery would have been disconnected while the engine was out.
    Apr 2012
    N. Wales, LL22
    1,224
    faulty switch
    VCDS in North Wales
    Jul 2012
    10
    Are they easy to swap. If so I will swap the front and rear switches over.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by paulr62 View Post
    Worth trying it again. Only a 1 minute job and that way you can rule it out.
    Jul 2012
    10
    Don't have a spanner in work to remove the battery. Will try when I get home
    Jul 2012
    10
    I have disconnected the battery for 10 minutes and still no luck. I think it might be a faulty switch anyone know a good place to buy a replacement?
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Turn the ignition on and hold the button 'up' till the window is fully closed, while still holding the button turn the ignition off & remove the key. Wait 5 seconds & release the button. Then put the key back in & test it again, this happens every other day with my drivers side switch for no reason & it's bloody annoying!
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Jul 2012
    10
    Quote Originally Posted by max69vk View Post
    Still not working unfortunately
  1. Drivers side window
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2009, 19:43
  2. Drivers Side Window Rolling Mechanism
    By Seifer780 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2009, 07:18
  3. Drivers side window questions
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2007, 18:52
  4. need drivers side window/green tint
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2006, 13:24
  5. Driver side window problems
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2004, 18:31
Tags for this Thread
