ok so that is the non cornering version.
since you have a pre-facelift electrics module and thats what the headlights is wiring into so the wiring you need to do should be as follows:
Original connector | new connector |
Pin 1- headlight range control | Auto leveller control module |
Pin 2 - headlight range control | Auto leveller control module |
Pin 3 - headlight range control (ground) | Auto leveller control module |
Pin 4 - Not used | Auto leveller control module |
Pin 5 - Ground | Ground |
Pin 6 - Dipped Beam | Dipped Beam |
Pin 7 - Ground | Ground |
Pin 8 - High Beam | Not used |
Pin 9 - Indicators | Indicator |
Pin 10 - Side lights | side light |
| Pin 11 - High beam shutter |
| Pin 12 - DRL |
| Pin 13 - Not used |
| Pin 14 - Not used |
So to get your lights working you would need to wire the connector the following:
Pin 1 (new connector, run a new wire) -> Pin 12 of the auto leveller controller
Pin 2 (new connector, run a new wire) -> Pin 19 of the auto leveller controller
Pin 3 (new connector, run a new wire) -> Pin 16 of the auto leveller controller
Pin 4 (new connector, run a new wire) -> Pin 18 of the auto leveller controller
Pin 5 (Original connector) -> Pin 5 (new connector)
Pin 6 (Original connector) -> Pin 6 (new connector)
Pin 7 (Original connector) -> Pin 7 (new connector)
Pin 8 (Original connector) -> Pin 12 (new connector)
Pin 9 (Original connector) -> Pin 9 (new connector)
Pin 10 (Original connector) -> Pin 10 (new connector)
Pin 11 (new connector, run a new wire) -> CECM (left side headlight to plug D pin 6, right side headlight to plug A pin 5)
That should then get the lights all working as per oem.
