Results 1 to 12 of 12
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Elsawin instructions needed
    I am going to attempt to fit new rear pad this afternoon and I'm looking for Elsawin instructions on how to do this task. i have got myself a piston windback tool, a 7mm allen key and copper slip is there any other special tools required to do the job
    My car is 2004 a3 3.2v6
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,608
    Only special tool needed is the caliper windback tool. I wouldn't even follow the Elsawin manual as its pretty straight forward..
    Remove the wheel and remove the caliper which is held on by 2 nuts (8-10mm iirc). Remove the old pads. Wind back the caliper with the tool. Lube up the caliper and the back of the new brake pads and reinsert. Tighten the caliper back up.
    Job done!
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    If you find you cant wind back the piston as its becomes too stiff...... wind it the other way as sometimes you can get a hydraulic lock within the piston and this releaves the pressure within it. As jb0o said its very straight forward and should take you no more than 1.5 hrs. Remember and monitor the brake fluid reservoir and drain if necessary as it will rise when you wind out the piston.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    I have got a 50ml syringe for the brake fluid.
    Thanks for the replies I didn't know it seems a simple task and I have Elsawin instructions now as well. So it's all good.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Well that wasn't a very productive afternoon the rear passenger side changed no problem but the drivers side the calliper had seized and took sometime to free also the rubber seal around the piston has almost came off and has some holes in it. But managed to get the brakes done but going to need to have another look at the drivers side when I have more time and see if there is anything that can be done to the calliper to fix it or just source a replacement for it.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Got a replacement caliper today so hopefully get it on at the weekend.
    Apr 2012
    N. Wales, LL22
    1,224
    Quote Originally Posted by Kelvin_S View Post
    Yeah rear pads were a pain in the ass for me 2. The rear nearside seized, bent my windback tool trying to wind it back, So I gave up and started pumping the brakes and the brake piston and seal fall out with lots brake fuild. Had to buy a new caliper and bleed the brakes. Never doing the nears again. Fronts are a piece of cake though
    you pumped the brakes with the brake off the car ????? lmao
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Apr 2012
    Quote Originally Posted by shariain View Post
    Shariain,
    Do you know the part number of the caliper? I've had exactly the same problem today with my 3.2 v6, same sides too. Can't even get the old pads back on so the car is going nowhere.
    Euro Car Parts seems to have two different models for rear offside calipers, is this where you got your replacement one from too?
    Regards,
    MT
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Quote Originally Posted by majortom View Post
    Shariain,
    Regards,
    MT
    I got my rear caliper from eBay someone was breaking a 2004 v6 I don't know the part number for it. I tried Tps £120 and ECP was £90 for a piage (sp) and a £40 retention until I dropped off my old caliper but had to be ordered and the one on eBay was a cheaper and quicker option for me got it for £40 posted was in great condition so was happy to go down that route.
    Hope you get it sorted soon.
    Apr 2012
    Thanks man,
    Any guesses to which one of these ECP part numbers would be the correct one?
    133443921
    133444431
    I'm guessing its the second one as its the most expensive and out of stock!!
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Thanks man,
    133443921
    133444431
    Sorry dude have no idea. You could try and get the original part number from the dealer or Tps and quote that to EPC to supply you the right caliper. Do they not have it listed with the size of the brake disc.
    Apr 2012
    Thats my confusion one part says "rear right" the other "rear axle right", both say 41mm piston. The only other difference is the first one also says 22mm disc which I think is standard on most models anyway?
    Don't worry, I'll give the dealer a shout on Tuesday, they're pretty good at giving out the part numbers.
    Thanks again.
    MT
  1. B7 to B6 Rear Lights coding, step by step instructions needed please
    By fullbor3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th December 2012, 21:08
  2. elsawin help needed please.
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2011, 12:57
  3. Needing a massive favour from someone with elsawin
    By PH1L in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2010, 22:15
  4. Need some help with Elsawin
    By Staz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2008, 11:23
  5. armrest installation instructions needed
    By a3page in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2005, 11:12
