Clutch Slipping? Replacement?
FINEST_A3
NULL
Hi my a3 has been revving a lot whilst in gear, whilst moving off and commonly whilst in gear, so i've figured that its slipping and its been like this for a while as it does it in gear 2, after having a read online would i need to replace the fly wheel aswel?
Also ive had a look at audi and they want 749 for a new clutch! and 839 for a flywheel! but ive had look on ebay and found these?
thanks in advance for the help!
Audi A3 1.6 FSI 8P Clutch Kit - 8/03 -> | eBay
Buy cheap, buy twice in my opinion...
Absolutely right....if you buy cheap bits,you usually get cheap results,and then end up spending more to fix it properly.
yeahh was thinking that but it does come with the 2 year guarantee? still better to just spend the extra 650?
thanks
yeahh was thinking that but it does come with the 2 year guarantee? still better to just spend the extra 650?thanks
Generally,you may get a warranty against outright failure,but once the part is in use,wear becomes the warranty issue.
Personally,I would forget that side,and just buy good parts.....they will last much longer than no-name cheap bits.
oh yeah, think ill just go for the audi one! Thanks mate!
Go to euro car parts or gsf n purchase a Sachs kit for about 450 it's the same kit Audi fit mate mate
Is the LUK one any good? as that was what was recommended by euro car parts and a lot of clutch specialists around
491
501
22
