Volks AutosAH Fabrications
    Feb 2012
    Excessive tyre noise toyo t1r
    Hi I have an a3 8p sport back that I fitted eibach sportline springs on and a set of 18 inch bbs wheels fitted with toyo t1r 225x40 tyres. Problem is that I am getting excessive road noise from tyres when the road surface changes to a rougher surface and also changing speed. Have had a read up on line and apparantly tyre tread pattern makes a differene to tyre noise.
    Has anyone else experienced excessive tyre noise from toyo tyres or any other tyre? Am considering buying new tyres if it would help.
    sachen's Avatar
    Jan 2011
    Leicester, UK
    236
    Ive already bought T1Rs whenever I have needed to change tyres. Never had an issue with them all. Saying that, currently not needed to change tyres on my A3 yet, but on other cars the tyres seemed awesome.
    J8TT X's Avatar
    Jan 2011
    Leicester
    337
    Could also be your tyre pressure?
    I have alot a noise when running 34 at the front, it goes a lot quieter when I use 36.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,301
    Tread pattern and different compounds do make a difference to tyre noise.
    I have R1Rs on mine and they are noisier than the PS3s they replaced,but some tyres like the F1Assys do combine good grip and low noise for instance.
    AwesomeHassan's Avatar
    Jul 2011
    53
    I have had Toyo T1R's before and there was slightly louder road compared to the Michelin ps3's I had on previously
    Jan 2012
    461
    Unfortunately better grip does = more tyre noise generally as there is more friction.
  1. Unusual Tyre Noise
    By Snake692 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2009, 08:46
  2. Excessive Tyre Wear?
    By A3 Sport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th May 2009, 13:25
  3. Tyre noise
    By mfspen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2006, 18:04
  4. Tyre Noise
    By S3DBW in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th May 2005, 16:18
  5. Tyre Noise
    By bigmoose in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2005, 11:50
