Sky InsuranceJMB Retrofits
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    hissing noise on idle
    i had a turbo go on me last week,had it replaced,took exhaust off a little oil came out of it,luckily no oil went in airfilter or pipes as was only doing 30-35 mph when turbo gave way,once all back together im experiancing a problem :
    above the battery is a black box with about6 pipes going to it........
    when i rev the car it makes a loud hissing noise which is noticeabl on idle too,ive unplugged the unit then the hissing noise dissappears,soon as i plug it in again the hissing starts,the turbo feels like there is lag just before it kicks in,is this something do with the unit?
    it was ok prior to the turbo dying,mechanic said maybe the cat has got blocked and its causing the unit to hiss,but im not sure cuz when i unplug it 1 pipe has suction on it,if it were hissing due to the cat being blocked it would be trying to breath rather than suck.........any ideas?
    Car stll smoke a little as ive only just got the job done today,what would symptoms be of a blocked cat?
    my turbo kicks in and car go's like a rocket,just get that turbo lag that i never had before.
    Full leather/19"wheels/cruise/
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Replied to your other thread about the same issue.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    _G_
    _G_'s Avatar
    Jul 2011
    869
    snake under the bonnet.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    serious though.. i had a hiss and it turned out to be a damaged pipe to the charcoal cannister... worth considering
