Monster MotorsportChris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Aug 2010
    1,540
    idle could be a few things .
    start with trying to remove the oil cap with it ticking over. see what it does to the idle.
    should be no more difficult than removing it when the engines off. and it should only upset the idle slightly.
    but if the cap is held down by vacuum within the engine crankcase. and on removing it if the car near stalls with a big rush of air thru the open oil cap..... then you need a new pcv valve unit thats attached to the cam cover.
    as thats where the engine is finding the unmetered air to upset the idle.
  3. #42
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    843
    Quote Originally Posted by murran View Post
    if its even half blocked it'll be causing the oil pump problems with what it needs to draw up.
    Thanks Murran ... there is a new pickup pipe in now and done 500 miles on it without an issue. Hopefully it didn't cause any damage while it was blocked.
  4. #43
    wuta3's Avatar
    Jul 2012
    843
    Thanks Murran, i'll give this a go tomorrow
  5. #44
    wuta3's Avatar
    Jul 2012
    843
    Tried this, the cap was certainly under vacuum and it did nearly stall the engine on removal with a whoosh of air.
    Is it a bad thing to keep running it for a few more days until I can get the part? Is that part 035 103 245 G ?
    Thanks!
  6. #45
    Aug 2010
    1,540
    suspected as much. give tps a ring they'll know all about what part/s you'll need.
    fitting's pretty easy. theres a guide on here somewhere (for an a3. very much the same on yours tho)......
  1. New and need advice
    By xander.p in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2012, 14:03
  2. looking to buy an a3 in january and need advice
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2010, 12:27
  3. Confused and need advice plz
    By Trick in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 21:36
  4. Cleaned it and need advice on what next
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2009, 22:47
  5. New and need advice!
    By tenbucc2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2004, 03:38
