Badger5Chris Nott
    Mar 2012
    EGR valve removal
    2.0 TDi 170 08 reg
    The EGR cooler pipe, which is stainless steel, is in the way of one of the fixing bolts for the EGR valve. I have removed the 2 mounting bolts for the cooler pipe but it won't move away so I can't get to the small EGR fixing bolt. Anybody got past this problem? Advice really appreciated.
    The pictures on the previous thread about cleaning the valve show a slightly different arrangement where the cooler pipe bolts on. Mine seems to be different and worse to get to the fixing screw.
    Thanks for any help.
    Apr 2012
    i always use a stubby 8mm allen key works like a dream even though the bolts are multi spline 10
  1. EGR and anti shudder valve removed and cleaned. Coated!!
    By Wats-on in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 21:44
  2. Removing EGR valve
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2010, 08:05
  3. CLEANING EGR VALVE-QUESTION-
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2006, 00:33
  4. Blanking plate for EGR valve. Does it work wonders
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2004, 15:12
  5. EGR valve
    By Pookie in forum Diesel forum
    Last Post: 29th July 2003, 16:11
