EM TuningBadger5
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By B5NUT
Thread: Help no sound from rnse
    Dec 2008
    north west
    120
    Unhappy Help no sound from rnse
    Hope someone can help my rnse has just stopped putting out any sound it still showing cd,s playing and sat nav but no sound
    Thanks in advance
    18"rs4s
    votex body kit
    full leather heated seats
    Rnse
    full electrics
    parking sensors
    auto dimming lights and mirrors
    full bose system
    cruise con
    sports pack
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Try tapping the volume button once (so it clicks), you may have put in into mute mode.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Dec 2008
    north west
    120
    Quote Originally Posted by max69vk View Post
    Tried this but to no avail its also started playing up and not finding my local stations think its something to do with my fin any help would be appreciated anyone know the best place to take it i live in the bolton area dont want to go to audi
    18"rs4s
    votex body kit
    Rnse
    full electrics
    parking sensors
    full bose system
    cruise con
    sports pack
    Aug 2012
    Quote Originally Posted by tony-b-3.2-v6 View Post
    Hi I am having the same problem - started today. No sound at all
    did you manage to get this fixed?
    cheers
    Jan 2012
    SW London
    794
    What systems do both of you have?
    If you have a rear amplified system and you have no sound whatsoever its mostly issues with the RNSe
    If you have full amplified (bose) then it could be either the amp or the RNSe
    Jul 2011
    106
    Re: Help no sound from rnse
    ^ Second this, check the fuse for your amp.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    or take the main fuse out and leave it 12 hour
    this will reset the unit
    if it dont work then no idea
    TONY i dont think your fin will stop the sound
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    if it turns out to be your rns i have one i can do you a good deal on (MK1 SDS unit)
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    27,121
    Do a reset by either removing radio & unplugging quadlock or press radio & setup together for as long as needs (usually 30 seconds or so) until screen goes of, see if this helps, if not then ideally needs testing in another car before sending of.
    Obscure I know but remove the nav dvd aswell.
    Aug 2012
    Thanks for all the responses.
    It is the Bose system I have - I have tried the reset option / checked the fuse etc. I will try taking the fuse out overnight - will also take the DVD out
    I phoned a couple of local audio garages - if it is the amp they are quoting between £300 - £500 to replace. Think I will attempt it myself!
    The unit itself if still working fine as is the navigation - just no sound...
    Hard job to do - anyone attempted it?
    cheers
    27,121
    AMP is plugnpray, so not to much trouble, just make sure you get the correct one, just little pita to get too, behind rear drivers quarter panel.
    Plastic_Badger's Avatar
    Aug 2012
    20
    Hi did you get this fixed?
    I have the same problem!!
    27,121
    Does it have Bose?
    Aug 2012
    20
    Yes, from looking at other threads, could be the amp by the sound of it (or lack of in this case!)
    Feb 2013
    Did u find out what was causing this issue I've got the same problem on my tt 3.2 it also has the Bose setup
    Aug 2012
    20
    Quote Originally Posted by tomos8304 View Post
    It was the amp. I fitted a used replacement one I bought off eBay and worked fine after, wasn't cheap though at about £100.
    Feb 2013
    Thanks for your reply I've just sent Audi customer services a email saying that I'm not happy & I want this resolved but I won't hold my breath , looks like I'll be forking out for a new amp.
    27,121
    On a car how old?
    Feb 2013
    The car is a 2007 but that's not the issue really I should of contacted them when the window regulator went (another well know issue ) but I just forked out for it, it's about time Audi addressed these issues,it's just a big money pit for them . I know people slag Renault off but I had my Clio 172 for nearly 10years & it never missed a beat maybe Audi should take some advice from them & sort there prices out accordingly
    27,121
    7 year old car, with respect you cant really expect everything to work perfectly for years & years, appeal to them for goodwill, but 7 years down the line I just don't see them being that kind unless you can show a repeated same fault on that chassis for numerous others.
    2,180
    Have to agree with NHN on this you have to expect some things to go wrong over the years, yes they can fail but I've got a couple of Bose amps from 2005 and they are still running fine. Also with the amps it's not really Audi's fault they buy them from Bose and Audi cannot test them for 7 years before they put them into production.
    NHN likes this.
    27,121
    Also factors could of contributed to the failure, heat, cold, dampness, all kinds of things, which may not have been the amp at fault but something connected shorted or had a surge, etc, these things all have to be seriously considered, it happens.
  1. NO SOUND FROM BOSE PLEASE HELP
    By jatbass in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2009, 22:26
  2. help needed, no sound from rear speakers
    By wellhouse0 in forum In-Car Entertainment
    Last Post: 22nd April 2008, 20:28
  3. no sound from h,u in s4 any help guys ?
    By bristol s4 in forum In-Car Entertainment
    Last Post: 11th April 2008, 15:27
  4. Losing sound from rear speakers
    By imported_micko2602 in forum In-Car Entertainment
    Last Post: 13th September 2004, 22:31
  5. No Sound from TV - yet CD/radio/SATNAV all work?
    By Patrick in forum In-Car Entertainment
    Last Post: 8th March 2004, 15:23
