JMB RetrofitsVolks Autos
Results 1 to 36 of 36
Thread: Turbo failure?
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    Turbo failure?
    Driving along i notice the slight tubo whine was now a whistle,so i put my foot down in 3rd gear arond 35mph,car cut out just as turbo was kicking in,thinking back im sure there was a 'pop' noise just before it died(abit like poping a bag of crisps)
    I first checked oil....it was ok,then i started it and drove it about 20 yards ...couldnt drive it as the smoke was very bad,i started it again and soon as i did smoke poured out......whiteish/grey ,i knocked the engine off re started it 2 -3 times after and still same,but this time the engine was running on even after i turned the ignition off, on/off....on/off with the ignition and it eventually stopped,the AA came and said do not start it or engine will get knackered,no coolant has been lost......seems like the turbo,thats why theres no oil left in the engine,before atempting to start it he said drain intercooler,put some oil in it then start it......there was also i hissing/whirring noise when i started it and AA said maybe turbo bearing has give in..........these the usual turbo symptoms?
    2.0 TDI BKD (2006)
    Full leather/19"wheels/cruise/
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    it's a BKD....they all seem to be going bang these days
    Sounds like turbo failure to me.
    Hope you get this sorted
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    and btw. don't switch it on anymore.
    that overrun could well continue and it will run flat out until its dumped and burned all the oil in the engine. then basically it really is game over, for the lot of it!!
    It will do this with the keys in your hand and not even in the ignition.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Quote Originally Posted by mjr901 View Post
    Thanks i hope engines ok.........just worries me.
    mikeyboy's Avatar
    Aug 2011
    349
    How much mileage is on your car just out of interest?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Quote Originally Posted by mikeyboy View Post
    112k
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    I thought the diesel turbo over run didn't happen nowadays? It used to make me cringe watching that happen
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    There's been a couple on here recently. including a video of one doing it.
    Not cool at all!
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Not cool at all!
    yeah not cool, its terrible and totally kills the car like I say horrible to watch if u love cars.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    is it worth replacing the oil feed pipe? and any seals/gaskets?
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    I would have good look round the turbo area make sure there's no oil escaped anywhere and check all your pipes/hoses that popping sound could have been a hose coming off under boost then post your findings on here. If you don't see nothing I would personally just go to a specialist lots of smoke is generally a bad thing, did the oil pressure light come on?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    no light came on,car wont rev over 2k unless it over runs,i knocked it off then
    Quote Originally Posted by cjsuk View Post
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    before i get the turbo fitted,how do i prime it?
    also how big of a job ist,and what labour should i be paying?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by vw754 View Post
    Always replace the oil feed pipe ! Part of the warranty on a reconditioned turbo is the mandatory replacement of the pipe (about £40 if I remember correctly )
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    oh im buying brandnew....genuine.
    thanks,any ideas on how to prime it.........what ive read,pull out fuel relay or fuse,or is it better to fill with oil where the feedpipe fits?
    Fossie
    Rhubarb Triangle
    3,969
    Sorry mate - not actually done it myself, just passing on info. I had been given.
    Not sure why you are buying new unless it's very cheap or a hybrid.! Mine went at 75k and a recon with two years warranty will surely do me nicely !!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    thanks........£862 inc vat new
    Fossie
    Rhubarb Triangle
    3,969
    Ah - ok, that's for fitting yourself obviously !
    Mine was £695 all in recon. fitted 'cos I don't have the expertise to diy it !!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    thats for a new genuine turbo from tps...priced today ! a couple years back it was £1200 !
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    one more bit of info i need.......im having the sump taken off aswell......is this a wise idea?????
    ive heard thers no sump gasket fitted but some kind of special sealant this true?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Ive just got some 'DIRKO' sealant for the sump,as that will be taken off and cleaned as a precaution,,,,,,,,,,any ideas of what the torque settings are for the sump bolts and also the bolts that go onto the manifold that holds the turbo?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    oh has anybody any idea what size bolts or nuts i need for the manifold ,may aswel renew them.when fitting the turbo.
    Old-Boy-Racer
    Have you checked the intercooler pipework yet? Had this on my 1.9 PD Golf Anni. Accelerated - loud pop - no power and loads of smok except on tickover. Turned out to be an intercooler pipe had cracked.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    yeah, but mine was dry as a bone on the dipstick.
    Quote Originally Posted by Old-Boy-Racer View Post
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    547
    with all due respect i would get someone to look at your car to give you a heads up on what needs to be done otherwise you might be throwing money at a problem you havnt got were are you based
    S3 8L ming blue westys old car shed loads of mods
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    going in tomorrow to a top mechanic friend,just thort id order some bits instead of car just sitting waiting for niggly little bits like bolts etc,turbo defo a gonner
  28. #27
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    I think you will find that the £700 turbo from TPS will be an exchange price and not the full price for a new Turbo. Our TDis shouldn't overrun to destruction that is why the IMF is there to starve the Engine of air when your switch the ignition off. That is off course assuming that your IMF is working and not jammed.
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
  29. #28
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    who mentioned £700 ?
    Quote Originally Posted by Gti Jazz Blue View Post
  30. #29
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    turbo all done,above the battery is a black box with about6 pipes going to it........when i rev the car it makes a loud hissing noise which is noticeabl on idle too,ive unplugged the unit then the hissing noise dissappears,soon as i plug it in again the hissing starts,the turbo feels like there is lag just before it kicks in,is this something do with the unit? it was ok prior to the turbo dying,mechanic said maybe the cat has got blocked and its causing the unit to hiss,but im not sure cuz when i unplug it 1 pipe has suction on it,if it were hissing due to the cat being blocked it would be trying to breath rather than suck.........any ideas?
  31. #30
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    A picture of what your trying to descibe would be helpful...
    Im guessing what your're trying to describe is no5 - the N75 valve? This is in effect a pressure relief valve for the turbo so it doesn't go pop at higher pressures than its rated for. If its hissing at idle check the pipes have been connected the correct way round & is even plugged in, if all connections are ok & it still hisses it will need replacing. Its only meant to release/recirculate pressure (at 2.2 bar?) back into the inlet intake & not below, which could explian the turbo lag if its not building up the pressure (due to the N75 leaking).
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  32. #31
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    its no5 yes,its worse when i drive,the hissing is coming from the hose that go's to the brake vacuum,,if i disconnect the pipe and put my finger on it,theres good suction on the pipe,which means its working ok for the brakes but why shud i be hearing it is the issue,maybe sucking outside air too.
    Quote Originally Posted by max69vk View Post
  33. #32
    Dec 2012
    Cornwall
    74
    Did this problem get resolved? I have just replaced my turbo after the turbine shaft snapping, was driving ok for 20miles or so but felt abit under powered. Now the car seems to boost really we'll but there is a loud hissing noise under load that can also be heard very faintly at idle near the vacuum solenoid box. Any info would be greatly appreciated as am abit worried to drive my car like this not knowing what's happening.
  34. #33
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    both ends of the egr pipe have to come off when yo replace the turbo for easier access....the pipe im on about is silver shiny metal pipe which has 2 alen bolts at each end its the close one to number 8 on the pick,both ends have gaskets,i replaced mine which solved it...go audi ask for 2 egr pipe gaskets £1 each.
    Quote Originally Posted by bagger_12 View Post
  35. #34
    Aug 2013
    27
    I had to replace my turbo due to a snapped shaft and I've also noticed there is more noise than I would have expected coming from the solenoid block. Its enough that you can hear air when someone else revs a bit on idle and you put your head close.
    I'm sure its lagging low down in the rev range and then suddenly spools. Are the blocks known for going?
  36. #35
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    its this: [QUOTboth ends of the egr pipe have to come off when yo replace the turbo for easier access....the pipe im on about is silver shiny metal pipe which has 2 alen bolts at each end its the close one to number 8 on the pick,both ends have gaskets,i replaced mine which solved it...go audi ask for 2 egr pipe gaskets £1 each. NOT THE BLOCKE=kyleseo;2047989]I had to replace my turbo due to a snapped shaft and I've also noticed there is more noise than I would have expected coming from the solenoid block. Its enough that you can hear air when someone else revs a bit on idle and you put your head close.
    I'm sure its lagging low down in the rev range and then suddenly spools. Are the blocks known for going?[/QUOTE]
  37. #36
    Aug 2013
    27
    Changed the gaskets - no difference.
    This is the boost graph from when the turbo failed:
    Looks like the classic coked up VNT but the vanes moved freely when the turbo was taken off.
    It still felt the same after the turbo was changed - laggy at low revs, lacking in power in 1st and 2nd, reluctance to rev. Turbo spooled up once the revs increased though.
    Checked the vacuum line from the actuator to the solenoid block and all seemed fine. Changed the solenoid block this week and all is back to normal. Boosts as it should do, no more lag and sudden spool, much happier to rev and the odd noise has gone from the solenoid block.
    I think the solenoid block was the cause of the over boost leading the the turbo failure in the first place.
  1. A3 1.8 Possible Turbo failure..?
    By JackSuperMoto91 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2012, 01:16
  2. emissions failure on audi a3 1999 1.8 non turbo
    By laurasa3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2011, 20:47
  3. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  4. Audi UK Will not warranty turbo failure on S4
    By ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2006, 11:41
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
