JMB RetrofitsVolks Autos
    Mar 2012
    278
    Run Battery Flat - ESP Fault
    Fitting lowering springs today and like a muppet left keys in the ignition with the radio on for too long. Went to start the car now and the battery is flat. Getting a warning message to say there's a fault with the ESP
    Will the warning message disappear after I jump the car? Or is the fault code going to need to be cleared £££?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Yeah it will go out
    Mar 2012
    278
    Thank you kindly, sir
    It didn't go out initially, but after driving the car for just a few meters the ESP and Power Steering fault lights disappeared
    Old-Boy-Racer
    Quote Originally Posted by SCFC_Messiah View Post
    This usually happens whenever the battery is disconnected. The ECU loses its sense of the steering's position - specifically its limits left and right. This causes the ESP to malfunction as it needs to know exactly where the wheels are pointing. Hence why the steering light and ESP fault are indicated. It can sometimes be cleared by turning the wheel lock to lock a few times. My mechanic told me to find a largeish car park and do several full lock turns left and right. It usually clears itself before I get there LOL
    Vertigo1's Avatar
    Jul 2006
    2,538
    I had to disconnect the battery a few times on my last car and basically half the electronic systems have a fit when you first start it again and take a few hundred yards of driving to sort themselves out again
  1. ESP Fault After Changing Battery
    By chrisb72 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2012, 14:58
  2. ESP fault - due to? Battery died or uneven tyre tread?
    By S3RYE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2011, 16:14
  3. ESP Fault on A6 (C6)
    By EddyH in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd November 2008, 22:34
  4. ESP Fault, Steering Fault - Re Retro Fit Cruise! Help Please
    By J7-AUDIA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2008, 12:17
  5. ESP Fault code
    By Jay in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st January 2008, 11:15
