Chris NottVolks Autos
Results 1 to 8 of 8
Thread: boost problem
    Jul 2012
    wolverhampton
    15
    boost problem
    hi ppl i have a bit of trouble with my audi a3 2.0tdi s-line 2005 bkd engine.it drives great but occasionaly it goes into limp home mode,when i stop and turn it off its fine after,also has like a whoosing kinda noise when i put my foor down have been to my local garage and they checked it with a smoke probe and said there was no air leaks they also plugged it in and it came up with glow plug4 and boost pressure control valve solinoid its seems like its over boosting could it be the solinoid?or somet else common on them?
    Fossie
    Rhubarb Triangle
    3,961
    People are much more likely to provide help if it can be seen that you have tried to find the information before asking the question.
    This is classic BKD engine symptoms of sticking turbo vanes and/or actuator faults.
    Do a search for the thousands of threads on here, this thread is actually a sticky at the top of this forum :
    GUIDE: How to remove turbo and clean 'sticky' vane, which causes overboost
    Jul 2012
    wolverhampton
    15
    checked the actuator how the guide says it moves freely smooth as anything,any other ideas ppl what i could be??
    Fossie
    Rhubarb Triangle
    3,961
    Turbo vanes stuck. Best cure is to replace turbo.
    Jul 2012
    wolverhampton
    15
    ok cool will have to take it off at some point to investigate,just out of interest the turbo boosts fine bit sluggish in 1st all other gears are fine boost wise just that bloody noise and when it goes into limp home mode how do the vanes stick?just when the turbo is at high temp?or just the build up of carbon?cheers for the help
    Fossie
    Rhubarb Triangle
    3,961
    Dunno mate - probably carbon/oil sludge. Mine just whistled like a police car and after testing for leaks etc. and not finding any I just had it replaced !
    Jul 2012
    wolverhampton
    15
    ok cheers for the info
    Jul 2012
    wolverhampton
    15
    deffo turbo veins were seized well bad had a new 1 fitted the other day,only slight whisttle coming from it any ideas ppl?oh always change the return pipe mine leaked like a ****er after it was refitted
  1. boost problems
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2005, 17:16
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
