Monster MotorsportChris Nott
Results 1 to 10 of 10
    JS3
    Oct 2011
    216
    Lowering - Questions and Help Needed
    Hi guys, so Ive seen a few motors around that have been lowered and decided to look into it for the S3. Im not going all out and changing to coilovers, reason being that I don't want to change too much of the car.
    I have done a little research but to be honest, I need some real simple questions answering from some of the guys who have already been down this line (bear with me...I don't have much experience of this field!).
    Car is a 2010 S3, S-tronic, 3 door, standard with no mods (so far!).
    So here goes:
    1. What is the max lowering I can achieve with lowering springs only on standard 18" alloys? I do not want any rubbing etc
    2. I have heard that lowering could affect the 'camber' (?) of the car - will re-tracking fix this?
    3. I would like a firm (but comfortable) ride - any suggestions on manufacturer I would choose? Ones to avoid?
    4. Scale of 1 to 10, how difficult is the job to do yourself?
    Sorry if these sound basic or stupid - still learning!
    Thanks in advance.
    JS3
    Oct 2011
    216
    Forgot to ask - I might look at some wheel spacers in the future - how will this affect things?
    Thanks again!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,290
    Morning,
    1. The lowest springs available are a 25mm drop
    2. A full alignment check after fitting will correct this
    3. H&R springs are one of the best suited options for the S3 - H&R 25mm Lowering Suspension Springs S3 8P / S3 8P Sportback 2.0T FSi Quattro 11/06> - £204.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts
    4. It depends if you have the correct tools and equipment
    Wheel spacers won't alter the handling a great deal, maybe give the car a little more of a planted feel but mainly for looks.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    JS3
    Oct 2011
    216
    Thanks Damian - so if I were to go for a 25mm drop on the standard alloys plus some wheel spacers, there should not be any rubbing?
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    I had my S3 (2008, 8P2, 3dr) lowered 25mm on H&R springs, with the standard alloys and tyres. I had 10mm spacers on the front and 12mm on the back with absolutely no rubbing.
    Also, fyi, 'camber' is the angle the wheel sits at when viewed from behind (the top of the wheel will be closer to the centre of the car than the bottom of the wheel when it's lowered). If you can imagine that the fixed point on the suspension arm (where the wishbone meets the chassis) is the middle of a curve that the wheel draws as it moves up and down and you'll get an idea of why lowering increases camber.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,290
    Quote Originally Posted by throttleaddict View Post
    You'd be fine on that drop with up to 10mm all round, anything more on the rear and you may get a little rubbing.
    Let me know if you need any prices as we have everything in stock.
    DPM Performance
    T: 01207 561606
    Jan 2012
    Glasgow, Scotland
    Hi Damian ive just seen your post, just bought a new S3 sportback, new to the S3 as ive always had R32's I've been looking at BBS CK's
    would i get away with the 25mm H&R Lowering spings and 19's or would it be safer to stick to 18's
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,290
    What width and offset are the BBS wheels?
    DPM Performance
    T: 01207 561606
    JS3
    Oct 2011
    216
    Damian (or anybody!), is there a fitting guide for the H&R lowering springs? I can get my hands dirty but I need some guidance before I start!
    Thanks in advance.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,290
    No but they're basically a straight swap for the standard springs.
    DPM Performance
    T: 01207 561606
  1. Murdered A4 pics and help needed please
    By dannyFR+tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th February 2010, 20:27
  2. Convenience module. Some questions and info needed.
    By qawsed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th February 2010, 18:05
  3. Hi all, thought I would introduce myself... and help needed please...
    By Rhymesaka in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2009, 00:15
  4. Hello!! New member and help needed.
    By S POT in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd October 2007, 22:38
  5. Alloys/Lowering Question Plz help!
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2006, 17:13
