Chris NottMonster Motorsport
Results 1 to 7 of 7
    sachen's Avatar
    Jan 2011
    Leicester, UK
    236
    Car stopped working - help please?
    Hi Guys,
    So was driving along, as you do over the weekend when all of a sudden my car cut out on me - struggled to restart itself but it did after a few turns.
    Got home and scanned the car to find the below:
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC G000SG 7364
    Revision: 12345678 Serial number: AUX7Z0F1FN90M8
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    VCID: 6CDCBF8D4F90D69
    1 Fault Found:
    16706 - Engine Speed Sensor (G28)
    P0322 - 000 - No Signal
    Freeze Frame:
    RPM: 0 /min
    Torque: 108.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.79 V
    Bin. Bits: 00101111
    Idle Stabilization: 0.0°KW
    RPM: 126 /min
    Readiness: 0 0 0 0 0
    So looking at this, it seems like my Engine Speed Sensor has gone. Am I correct in assuming this? Have checked Ross Tech Wiki which lists all the symptoms which I have.
    Thanks for the help!
    Sachen
    _G_
    _G_'s Avatar
    Jul 2011
    869
    yes you are correct
    sachen's Avatar
    Jan 2011
    Leicester, UK
    236
    Has anyone had this issue before? I can see the actual sensor is roughly £30, just wondering about labour costs/time etc?
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    aka the crank shaft position sensor, mines an 8l 1.8t aum but I presume they are roughly the same, mine was intermitant and the engine would cut out every now and again, I replaced with a golf mk4 aum sensor for £4 from the scrappy, fitted it (pain in the rear), and it's been on a month now and it's been 100%. Ill send you a link to my post.
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    sachen's Avatar
    Jan 2011
    Leicester, UK
    236
    Sounds like you had the identical problem to what ive currently got. Same error code as well more or less!
    I have a BKD engine. Will get the part changed and hopefully it will sort the issue out...
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    its amazing how a little magnet a piece of wire and a bit of plastic can stop a whole car from working and cause so many different problems
  1. Car wont crank??? help please
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2011, 00:20
  2. Is my car an import? Help please
    By A3Bash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th January 2010, 19:23
  3. Rear washer jet > stopped working > HELP!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2008, 19:34
  4. Car Starting problems - Help please
    By max10 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2007, 10:05
  5. Replies: 1
    Last Post: 10th May 2006, 01:19
