Volks AutosChris Nott
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Coilovers and camber..........
    I would like to drop my a3 but I don't want to scrub tyres ......
    I have had lowered cars in the past and I was changing tyres all the time
    Am I right in saying I can adjust the rear camber but not the front?
    If so is there a suspension set up which allows for 4 wheel camber adjustment?
    I'm running a 2.0 tdi s line 140 quattro by the way
    Thanks Jack
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,803
    All depends on how low you go, size/et/width of the wheels and tyres. You can get H&R adjustable top mounts for the fronts they are about £380 and allow 1.5-3.5 degree camber. What wheels you planning on putting on and how low do you want to go? N8 the guy when it comes to wheels/suspension lol i'm sure he will be along soon!
    Dark Vader Half sibling - MyThread
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    iv got 18 inch dare nk1s 8j im not sure of the offset
    is it worth just going for aftermarket springs rather than coilovers if once they are set there gooing to need checked every time the ride height is adjusted?
    how low do people go before tyre wear is a problem?
    i dont want it to be bad because at a hundred quid a corner its not like you want to be changing them every 5 minutes
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    front camber won't be much when lowered. rear will be more but i guess you can adjust it more. mine is with kw v3 and whiteline anti lift kit (which adds a little negative camber) and the front is maxed at -1° while the back is at -1.5°. tyre wear doesn't seem to be an issue..
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  1. Updated pics, now slammed on coilovers, and more!
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2009, 15:01
  2. Newbie and Pics coilovers and some different wheels
    By sworks16 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2008, 16:29
  3. Coilovers and Sideskirts for A3 help
    By gordybaillie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2007, 22:51
  4. Coilover and air filter help.
    By imported_kennyf in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 14:38
  5. tockico coilover and stuts/ shock
    By rafA4 in forum Handling
    Last Post: 12th June 2004, 16:53
