Badger5Sky Insurance
Results 1 to 9 of 9
    Aug 2011
    10
    Will any other amp fit replace my broken Bose one?
    Will the 8L0 035 223 fit where my broken 8P3 035 223 was?
    Dont really want to spend £150+ on a replacement amp and the earlier ones are a lot cheaper.
    Thanks.
    Mar 2011
    Cleveland
    989
    Is this what you want?
    Classifieds: Bose Sub A3 8P
    Aug 2011
    10
    Thanks mate but no, it's a separate amp on the opposite side of the boot.
    Mar 2011
    Cleveland
    989
    Oh! Didn't know about that one....
    Aug 2011
    10
    Anybody?
    J8TT X's Avatar
    Jan 2011
    Leicester
    338
    I asked a similar question a while ago but never really got a definet answer.
    I was told that you need to get the exact same amp. Dont know if this is correct?
    Also not sure if any other models use the same amp as the A3 P.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Aug 2011
    10
    Anybody else?
    Feb 2012
    16
    Hi,
    I searched high and low for a replacement Bose amp for my 04 2.0 Tdi and came across the same problem, nobody could/would confirm that a similar Bose amp from and A4/A6 with a similar number would be interchangeable. I rang Audi and spoke with an 'expert', he stated that you had to have the same one to the one you are removing. I searched high and low in the UK and could only find a replacement at £150+ as you have found, my expert at Audi advised new is £400+!!
    I ended up locating one on Ebay in Germany and made an offer, which was accepted and cost me just over £100 delivered to the UK. He did have more than one when I bought mine a few months ago!
    Just need to find a working (no volume problem) Concert for it now.
    I take it your amp got wet behind the rear trim panel, causing it to melt out, great Audi design to place an amp under the rear washer pipe joint!!
    Good luck.
    Steve.
    Aug 2011
    10
    Thank you for the great reply Steve.
    I've managed to source one now after a couple weeks of hunting.
    No idea if it's because it got wet, it just started crackling and popping every now and then until one day no sound at all.
    Picking up the amp tomorrow so will reply with results.
    Thanks again.
  1. Will any A3 head unit fit?
    By jbaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2012, 15:30
  2. Standard Turbo + Remap. Any other performance parts worth fitting?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2006, 21:55
  3. Do A6 or Passat seats fit into a b5? or any others
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 20:30
  4. A8 1997 17" Sport wheels -- will 255/50 17" fit?
    By hanssimon in forum A8/S8 forum
    Last Post: 1st April 2004, 20:52
  5. Replies: 7
    Last Post: 3rd January 2004, 19:52
