Chris NottSky Insurance
Results 1 to 13 of 13
    Nov 2011
    70
    S3 clutch - how long will it last once it slips
    As the title suggests guys I am having my 2008 S3 remapped soon to stg 1 and am aware the clutch us weak but just wanted to check when it starts to slip will it fail instantly or keep slipping for a period of time. Just wondered as I work away a lot and didn't want the clutch to fail whilst away from home. I am hoping to get at least 1000 miles out of clutch (car has done 22000 miles) but I know its unlikely or do you think its possible?
    Jun 2011
    138
    depends how you drive
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    yep ^^
    depends on map aggression too
    aggressive obviously not as long...
    progressive little bit longer....
    Have you budgeted for a new clutch yet?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    Just avoid pedal to the metal in high gears(4,5,6) and you should be fine!!!
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    I had mine stage 1 mapped at 20k. it lasted less than 1k. I drove it hard...very hard. the map was agressive and a bit sh1t to be honest. (chipped UK)
    but who wants to drive a mapped car like a daisy huh?? I want to use that power, dunno about you!?
    if the budgets there, do the clutch, saves worrying. ease it in for a few thousand miles.
    Nov 2011
    70
    Thanks guys. I am getting a revo map as there is a dealer close to me. The budget is there to do it when needed I just hoped it would last a little while. Will it slip for a while but be driveable or do they just fail instantly as I work away from home so if it started to slip I would need to get home?
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    It will get progressively worse once it starts to slip but you could nurse it for a good few 1000 and still get about before changing it.
    I have had this happen on 2 x 20TFSI cars (both REVO`d) and neither catastrophically failed so you shouldnt worry about being stranded, although AA cover is cheap enough.
    Good luck
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Mine did pretty well on Stg1,but gave up immediately on Stg2.
    When it does begin to slip,if you do as Paul and Pinterovski have said,you will be able to use it until you get it replaced,as it's usually the clutch's torque limits being exceeded,as opposed to the thing being worn out,but if you keep it slipping it will burn out very quickly.
    The Sachs organic is a good replacement,as is the Loba.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by S3Alex View Post
    I'm going stage 2 a week on friday, (only because it's £50+vat with Revo) hope mine lasts longer than immediately because i'm going to germany in the car a week later. I don't drive it hard all the time and i never do standing starts.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Quote Originally Posted by DJ-S3 View Post
    Treat it fairly gently and it may last for a while.
    Peak torque is what kills it and that's about 3500-4000 rpm esp in high gears so if you avoid full throttle in high gears you should be able to avoid problems until you replace it.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    That'll be alright until i get to the autobarns in germany, oh and round the nurbergring so basically i'll be looking at a new clutch as soon as i get back if i'm lucky!
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    How the hell do you guys drive it above 3500-4000 in the high gears and not lose your license (other than a trip to Germany)?
    I ring my car out in second and half way through third but then I'm doing well over 100km/h which is our limit, any more than 25km/h and we lose our license.
    Mind you I live in central Melbourne so I don't drive on open roads where this is possible very often at all.
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Quote Originally Posted by poli84 View Post
    The answer is very rarely,and very carefully.
  1. How long will the brake discs last (Audi RS4 B7)?
    By Cartéen in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 1st December 2011, 16:54
  2. how long will my 2.0 tfsi last?
    By DTM1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th November 2009, 09:15
  3. How long will it last?
    By Danny Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2009, 16:33
  4. Max miles to buy an S4 with? How long do they last?
    By sam_pd in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th June 2006, 23:25
  5. How long do turbos last roughly? And other questions??
    By DelBoyUK in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2005, 21:06
