Monster MotorsportEM Tuning
Results 1 to 9 of 9
    Sysmic Wave's Avatar
    Jun 2012
    Resyncing my key fob
    Hi folks, I know that there are a million topics on this issue but I just can't find an answer that helps me.
    The girlfriend has just bought a 2004 A3 and we received two keys with it. Unfortunately one of the keys doesn't unlock the doors via the buttons and as well as change the battery I've tried every method I could find to resync it.
    I finally gave up, thinking the key was broken, and bought a new key (same part no) from a certain auction site. The new key arrived but I cannot sync this either. I'd say I'm technically minded so this is starting to annoy me.
    Does anyone have any idea what I am doing wrong? I have VCDS if that can help.
    Thanks for your time
    Fossie
    Rhubarb Triangle
    3,961
    You can synch it using VCDS so that it locks/unlocks but I've never done it so someone else will be along to explain.
    However, you will not be able to start the car with the new key because the one-off immobiliser chip inside will not work with the immobiliser in the car. For this to work you need to get a new chip and have it coded with a code, part of which is only available from Audi Germany. That's why dealers charge up to £200 for a new key !
    Jun 2012
    Thanks for getting back to me.
    I already have the chip from the second key which wouldn't open he doors. This works fine and I can start he car. It's jut the central locking I'm having problems with.
    Jun 2011
    Great Melton Norfolk
    1,340
    You will need the skc,code from clocks/dash , unless you have it. might be on a scratch off panel with the keys /in handbook case.
    Then you can reprogramme the keys using vcds
    Apr 2012
    N. Wales, LL22
    1,224
    you only need the code to program the imob, the locks can be done just with vcds
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Jun 2012
    Cheers, but does anyone know the correct VCDS procedure for her 2004 1.6?
    26,749
    Do you have a genuine vcds?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    When the remote part of one of my original keys started to play up I bought a second hand one one Ebay, put the two together and tried to sync using the instruction in the manual - no joy. Found out why, when I then got my VCDS out - the remote module in my 2005 A3, can only have two remotes paired to it.
    Beware when you program with VCDS, you will need both remotes available, that you want to use with the car, as the proceedure involves deleting all stored remotes and then adding the two that you want.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Jun 2012
    Quote Originally Posted by Gti Jazz Blue View Post
    Paul
    Cheers mate, that worked great.
    I had to make sure that I erased all matchings on channel 00 first. Then on channel 01 I entered 2, hit save and pressed the unlock button on both remotes.
    Now working and I'm a happy bunny! :-)
  1. Key fob programming (resyncing)
    By c_w in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2011, 18:56
  2. Remote Key Fob
    By macca666 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2006, 07:05
  3. Key and Key fob
    By imported_Cali in forum Detailing
    Last Post: 14th December 2005, 21:21
  4. key fob total closer
    By ALISDAIR in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2005, 22:27
  5. 2 Button Key Fob
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2005, 20:14
