EM TuningSky Insurance
    Dec 2009
    21
    ESP fault code 01435 Brake Pressure Sensor - Common fault apparently
    Hi all,
    Has anyone else experienced this fault?
    The ESP problem flashes up on the display and the warning light stays on.
    How much for the replacement, been told to expect around £800 fitted. Audi acknowledge there is a fault with the units but instead of recalling them they reduced the repair cut price.
    Think i'll be looking to part with my S3 shortly, 5 years old and now it's starting to do my head in!!!!!!!
    DenniS3
    Ghost's Avatar
    Boo!
    Jul 2009
    Wales
    1,040
    Hi DenniS3, my ESP light stayed on and had the same fault code.
    It was the ABS Pump that i needed replacing, £800 fitted
    The part that Audi acknowledge there is a fault, is the Pressure Sensor Switch
    Dec 2009
    21
    Its in today getting fixed. hopefully i'll have no more issues.
  1. Audi S4 brake pressure sensor problem, 01435.
    By antboo1.8t in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2011, 20:08
  2. Replies: 2
    Last Post: 19th December 2010, 20:41
  3. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
  4. 01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
    By Jay.Ing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2009, 16:03
  5. ESP Fault code
    By Jay in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st January 2008, 11:15
