Chris NottAH Fabrications
    Feb 2012
    Kirriemuir, Scotland
    33
    Cam tensioner oil leak on 2007 S3
    How big a job is it to fix this problem? I have been informed it is a common fault with the S3! Is there actually a gasket or is it a vaccum seal? I have searched for threads relating to this problem but could not find any
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    I've got a oil leak down the back of my engine (isn't enough to drip on the floor though) is this the same? Can't get far enough up the engine to find where it's coming from :s
    SiT
    Apr 2008
    Tyne & Wear
    98
    Never came across this on mine after 4 years of ownership. Keep the servicing up to standard and treat the puppy well and you may not have this issue. You'll always hear of problems with cars but remember that car forums inevitably report defects but that is a vast minority to the good cars out there. Always look for a good service history backed up with invoices, bit of a lottery but always a good basis to start.
    Good Luck
    Feb 2012
    33
    Mine has full Audi history and every receipt to prove all work done, has been well looked after! It was my friend who works for Audi in Aberdeen that told me it is a common fault. Just trying to find out how common. DJ-S3 no my leak is on the right hand side of the engine looks like it is coming from the cam tensioner, tbh I think I will just get my mate to have a look and see what he thinks
    Feb 2012
    33
    Turns out it was just a breather pipe so nothing to worry about
  1. 2007 2.0 TDi Quattro 170 S Line-Oil Leak
    By SWILKO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2012, 19:32
  2. Small oil leak near cam belt
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2009, 19:47
  3. OIl Leak - Help Please
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:29
  4. Oil leak found after having car at dealers
    By ianburtney in forum General Technical / How To
    Last Post: 14th June 2004, 08:19
  5. Oil Leak found after having car at dealer
    By ianburtney in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2004, 08:16
