AH FabricationsSky Insurance
Results 1 to 11 of 11
    Apr 2011
    Doncaster
    68
    Audi Service History record
    I bought my A3 with 80,000 miles and a full Audi Service History. I assumed (or the seller told me, can't quite remember ) that the timing belt had been changed as Audi recommend this is done around 75,000.
    After checking through my service record book I've noticed that a timing belt change hasn't actually been recorded in there, however I have a 'Vehicle service history guarantee' from ALD automotive who were the fleet management company that owned the vehicle before me.
    This guarantee says that the timing belt was changed by Halesowen Audi in the west mids at 72,004 miles at a cost of £263.64.
    Now I was just wondering if I was to ring Halesowen Audi and give them the vehicle details if they could check back over there records and confirm if this is actually the case?
    Also do you think they would stamp the service book to say this was done?
    Tom
    2007 1.9 Audi A3 8P Sportback
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Give them a call mate and they should be able to tell you as it will be recorded on their system.
    Also yes, the book should be stamped but I have experienced many times in the past when the main dealer have forgot to stamp the book after the services.
    If the job has been done, then bring the book to them or send in if too far and they should be able to stamp and back date it.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    A service stamp is a service stamp. If a cam belt is done on its own, without a service, then it wont be noted in your service book. You have the invoice and relevant paper work to prove it so that's enough in my eyes.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Quote Originally Posted by A3Kent View Post
    Mine was.
    Either way, call the garage & they can confirm exactly what was done & even what parts were used/replaced if you need to know.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Fossie
    Rhubarb Triangle
    3,969
    Yes it will. There is a place in the service book to record cambelt change (and stamp) - I have one !
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    So you just had a cam belt done on its own and you had your service book stamped?
    Fossie
    Rhubarb Triangle
    3,969
    Stamped and dated that the cambelt had been changed including the mileage recorded. Why do you sound surprised ?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    But was it done as part of a service? I had a cam belt done (just the cam belt) on a previous car and the book wasn't stamped and I assumed it was because a interval service wasn't carried out at the same time. Maybe I'm wrong
    Fossie
    Rhubarb Triangle
    3,969
    If you get the cambelt changed, regardless of servicing, you just ask whoever has done it to mark the mileage in the book and stamp and date it with their official stamp.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    +1
    Had my cambelt done in its own and had a full Audi stamp, date, mileage and toothed belt box ticked.
    Apr 2011
    Doncaster
    68
    Spot on, thanks guys. I'll give the said dealer a call tomorrow and see if they can help!!
    Tom
  1. "Full' Audi Service History - Worth it?
    By hazey7 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th February 2011, 13:53
  2. Full Audi Service History - Worth Keeping Up?
    By hazey7 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd February 2011, 13:17
  3. Audi service history
    By Duktor in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2010, 17:51
  4. Audi Service History
    By Hotscar in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2008, 19:34
  5. Full Audi Service History
    By IDUA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2007, 19:12
