Chris NottSky Insurance
Results 1 to 7 of 7
    Dec 2011
    11
    VCDS Collant temp
    Anyone with knowledge in what the coolant temperature should be on the highway when just cruising?
    Mine is about 81C and when i get in to town it goes to 79C when driving. When i stop the coolant temp will go up to 90 + and the fans will start as they should.
    I need to confirm that the coolant temp should stay at 90C when driving normally. According to what i read on some forums it should always be 90C and if not the car will automatically push in more fuel and cause the rich status i have.
    The cluster gauge itself will always show 90 C but i need to know what the real VCDS read should be.
    Fossie
    Rhubarb Triangle
    3,969
    VCDS should tell you the temperature range if you 'hover' over the appropriate measuring block ( I think ! )
    Dec 2011
    11
    It does, states 80 - 105 . But someone with another 2.0 TFSI engine told me their always stay on 90 C when reading with VCDS.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    It can't stay exactly at 90. It is normal to be lower when cruising and to increaqse when stationary. You should worry if the temp sits below 80 even though the engine is running for a while or if it raises above 105 (and the fans don't start)
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Dec 2011
    11
    Quote Originally Posted by Johnny Bravo View Post
    In other words my cooling is really effective and car ECU will not pull back on timing or add more fueling to correct things?
    6+1 Gears
    Jun 2009
    Romania
    797
    I don't know these details but I don't think you should worry.
    If the temperature is not in the normal limits I think you'll notice side effects.
    My temp sensor had a problem and did not show more than 55 degrees on vagcom so the ECU always ordered more fuel than needed thinking that the engine is still cold. Even if I wouldn't have seent the temp gauge I could tell there is something wrong because the MPG dropped very much.
    Dec 2011
    11
    In my case my AFR (lambda) are down to 0,70 so running rich. My MPG seems to be good but i can feel i have hesitation on full throttle. Just want to find the cause to my issue. So question is if 80 C will make the ECU push more fuel or not. I worry cause i have issue with my engine simply. Thankful for your input anyway =).
    If anyone with VCDS can check when they are driving let me know.
  1. VCDS Temp reading high?
    By S3Lol in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2011, 11:17
  2. Brakelight sensor + collant temp sensor
    By womb raider in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2010, 21:38
  3. Can I Activate Temp Display?
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 22:40
  4. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
  5. S3 Temp Sensors
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 16:53
