Results 1 to 9 of 9
    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    DVD sat nav plus rns-e pictures
    can someone quickly point me in the direction of a picture of an a3 centre console with the above fitted. ta
    imported_trident21
    Re: DVD sat nav plus rns-e pictures
    Here is a big one:
    Pic
    and here a few more...
    Pic 1
    Pic 2
    Pic 3
    Pic 4
    Pic 5
    Oct 2004
    Surrey, UK
    298
    you know what... that first picture has made me realise that the SatNav+ has (almost) built with the right hand driver in mind... think about it. in a LHD car, the screen 'could' be partly obscured by your hand/arm on the steering wheel, and the control are further away from you, where as in a RHD car the screen is in free view and the controls handy and close to use.
    how strange!
    imported_unkle
    http://cgi.ebay.de/ws/eBayISAPI.dll?...558100925&rd=1
    Just came across this, might be useful...
    gizze's Avatar
    Dec 2003
    Norfolk
    615
    That is for an A6 though.
    Nov 2004
    cambridge
    75
    Does anyone know if you can fit that advanced sat nav into an S3 or does it need to be in the new A3 to fit/work?
    Oct 2003
    up north...
    767
    if you have a facelift s3 with digital clock on the instruments then you have can-bus
    the a6 rns-e has all the right connectors and seems to be the right height if you have a double din radio slot- only the faceplate would need cutting on its left and right sides
    you might have to run the can-bus wires from the cluster to the back of the radio - but this is only a 15 minute job
    all the other bits are plug and play and are available from www.kufatec.de as well as others.
    if you have a boot changer or phatnoise then this will work as well.
    you can do the whole thing for under 1000 and a couple of hours work.
    gizze's Avatar
    Dec 2003
    Norfolk
    615
    Is that at me? The climate is recessed when you have a double din system, I had Symphony before putting the Nav+ in.
    Eeef's Avatar
    Lord of War
    Nov 2004
    1,602
    Is the unit the same model as for the single din stereos? Can't find it on ETKA.
