Badger5EM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
Like Tree1Likes
Thread: A3 3.2 2004 missfire
  1. #41
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    On tic over mine is open
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
  3. #42
    Jun 2012
    Orpington Kent
    32
    Anyone know how the exhaust flap works an how to test it? I can manually close it.
    Also what is the correct sparkplug gap?
    I did a site search for type of plugs an gap but only found for older models.
    An 1 other question to do with the engine to exhaust metal earth strap hanger thing. what would make it snap?
  4. #43
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    there are a good few threads on here about the exhaust valve and modding it and you will also find links to r32 forums that will tell you about the operation of the valve.
    also have a look here all i done was use google for audi a3 3.2 v6 spark plug gap - Google Search and the 1st 2 results give you the answer you are looking for the gap in the plug
    Audi A3 Sportback (8PA) 3.2 V6 quattro Spark Plug from Bosch
  5. #44
    Jun 2012
    Orpington Kent
    32
    So the sparkplug gap 0.9mm. an you say the bosh plugs.
    An any ideas why that hock would break, is it common?
  6. #45
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,196
    I think the exhaust strap breaking is quite common due to the movement of the engine. Mine was actually missing but made no difference when I replaced it tbh. I also had to have both flexible joints replaced on the downpipe as they were leaking..
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
  7. #46
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Quote Originally Posted by TrebleTA View Post
    i was not saying to use the bosh plugs or it should be bosh plugs, i was just saying all i done was google the spark plug gap for a3 3.2 v6 and it came up with the info required. if you go to ngk's website and put in the info for your car it will tell you about there plugs and that the gap is preset
  8. #47
    Jun 2012
    Orpington Kent
    32
    I did as you said an only way i got the spark plug gap was by looking at the plugs preset. But often there preset is wrong that is why i was asking also pugs will change in sight slightly so knowing the correct gap you can easy set back. when i said i did a serarch it was just this site an only plug gaps was for the s3.
    3.2 ju, you said it made no difference to your car. is there any other earthstraps on the exhaust. also now its not there as i removed from the car is. I now get a knocking (prob from the exhaust) an the esp has come on.
    Called audi up for a new bit an there dont have a clue what i mean so have to go to them!
    Just went there will take over a week to get the bit.
  9. #48
    Jun 2012
    Orpington Kent
    32
    Fitted the new bit an the miss fire is still there, From what i can tell its number 6 that doing it.
    The only thing I can think of it being is the injectors. what else would cause a miss on 1 cylinder no:6 changed plus an coil pack.
  10. #49
    Jun 2012
    Orpington Kent
    32
    Ok been driveing the car now the miss fire now seems very random like 1 min i can stop at lights the revs are at 750 more looking an runing fine with no missfire, think after i give it a good boot. then 10 min later will be about 600-500 rps an will get the odd miss, when more cruseing. Have noticed a faint knocking also belive its the cluch as push the peddle down noise go's, only noitce on tickover like a floating cluch plate?
  11. #50
    mechanic69's Avatar
    Mar 2007
    374
    My 3.2 had the hesitant acceleration and the idle sticking at 1000 then dropping to 700. Kept throwing P1142 error until I did this. You could feel the car accelerate in stages. Removed the throttle body and gave it a good clean especially around the butterfly "hinge", improved it no end and no hesitency any more. Only cost a can of carb cleaner and 30 mins of my time.
    S3 - Sprint Blue BE [MY11] My Build Thread
    Options - Satnav, Bluetooth, MFSW, Privacy Glass, Nappa Leather
    Mods - Bluefin Stage 1, DV+, Revo Race CIA, Cruise, TPMS, Bilstein B8s, Eibach Pro Kit, H&M Spacers, Exclusive Leather Trims
    Future - Downpipe sports CAT, HPFP, Stage 2+, ALK, ARB, 2nd Mortgage
  12. #51
    Jun 2012
    Orpington Kent
    32
    But i think if you removed it an cleaned you need to get it reset?
  13. #52
    Jun 2012
    Orpington Kent
    32
    Ok tock it off give it a good clean then let it rest by start getting the dash lights on a waiting 2 min, seems the same but, as went slow over a round about was like i put me foot on the peddle an well nothing happend yet then was fine after. like it was starved of fuel or air, also i have started to notice a black soot on the back bottom of the exhaust tale pies, any clues
  14. #53
    Mar 2008
    Is the erratic idle getting worse over time? Are you unable to hold a constant 2000rpm idle when the cars in neutral? If the answers are yes I would strongly suspect you have the cam-chain/cam-chain adjuster issue. Get it looked at asap as the longer you leave it the worse it will get. As for the soot on the bottom of your exhaust tip, that's normal carbon deposits. If the soot slowly builds over about a week that's normal and should wipe off cleanly with a damp rag/spounge. Anything heavier then you may have a problem. Get it booked in for a full health check is my advice.
    2004 A3 3.2 Quattro Sport DSG S-line
    2008 KTM 950 Supermoto
    1988 Honda CBR400RR Tri-Arm
  15. #54
    Jun 2012
    Orpington Kent
    32
    Thanks for the reply daver555. you could be right its the only thing left, an i get a warning via the computer readout for it... just audi did say too me that it was fine as was not that 90% sure, why i have not had it done yet. But its saying the chain is too tight by -1
    also get a missfire on 5 an a minor on 3 from what i can tell. will have to get it check out only way to be sure.
    If anyone know a good garage that not going to break my wallet, am out of work now... i would do it my self just not totaly sure, I'm in the bromley (kent) area.
  16. #55
    Feb 2013
    Midlands
    Quote Originally Posted by 3.2 Ju View Post
    Get the software update done ASAP, they are the exact same symptoms mine had before and after the chains were done!
    hi there,
    I very recently bought a 3.2l Quattro and I have exactly the same symptoms, after reading this tread i brought it to Audi but after a check etc .. They said that there was no update available for this car. would anyone be able to provide the details of the update needed please ...
  17. #56
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Quote Originally Posted by Mall-uk View Post
    hi there,
    Here is the info I found for the update
    Engine software update
    Tpi 2010289/3
    Sum 8P01A005
    Update disk 4F0906961N
    Mall-uk likes this.
  18. #57
    Feb 2013
    Midlands
    Quote Originally Posted by shariain View Post
    Tpi 2010289/3
    Sum 8P01A005
    Thank you for the reply Shariain , I ll try this with the garage , as the shop floor manager was very helpful tbh , but the disk update ref is a ref for an A6 (4F start) should it not be starting with a 8P ?
    Have you had the update done on yours ? If yes what audi garage ?
    My car was first registered in March 05 , what year was yours registered ? Did you get your car
    Pthanks again for the the much needed help ...
    P
    Mall
  19. #58
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    I have not had the update done on my car as when it was in for the coil recall I said to Audi Glasgow about this but they told my it didn't exist but the info for the update was found on this forum and I just copied it down and kept it for the next time I'm in at Audi so I can give them it and get the update done. If you do a search you will find lots of info on this update.
  20. #59
    Feb 2013
    Midlands
    Just did a search on it and it seems that few peeps were having the same problem with their 3.2l (incl TTs ) even seen that some were from Birmingham or Northampton which is close .. I ll ring Audi tomorrow and see (hope) if they can help ...
    If anyone had the update done in the midland area please let me know ....
    Mall
  1. 2004 Audi A4 1.8T XM READY
    By metroaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th April 2004, 16:31
  2. 2004 A4Q 3.0 h.p. gains???
    By cmel in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2003, 05:11
  3. 2004 Audi A4 1.8T Sport
    By markpetty in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th November 2003, 00:50
  4. FPA Test for 2004?
    By djmotorsport in forum Motorsport
    Last Post: 6th October 2003, 09:38
  5. S4_____Bi-Turbo or 2004 V8..... what do you think
    By SimSimma in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2003, 18:53
