Chris NottAH Fabrications
    Mar 2012
    23
    Airbag light and Rear Wiper on my A3 TDI Sline 3 door.
    Hi Guys,
    I have a TDI 140 Sline 2004 (54). Had car on VAG Com a couple of weeks ago whilst at Midlands VW in Cannock. Thankfully no fault codes found. Two weeks later (yesterday Morning) the Airbag light decides that it wants to have a staring contest with me it looses and goes off. It is rather intermittant comes on when the car is switched on goes off after a 5-10 mins.
    Any ideas what it could be. I am from Birmingham so if it requires another VAG Com connection, does anyone know anyone who is birmingham based that may be able to assist.
    Also the wiper motor i think has packed in as the wiper has stopped in the middle of the rear windscreen. I have been looking on the 'bay' and I have seen a used motor from a 2002 mk4 tdi which looks the same and has a similar part number. As far as I am aware I need part number 8E9 955 711 E can anyone confirm. Also will parts with the same number but ending in A, B, C & D work on mine.
    any help would be appreciated.
    foxymk1's Avatar
    Apr 2012
    doncaster
    196
    hi mate, my rear wiper stopped like yours so i just put the stalk in the action position with ignition on then went to the back of the car and with abit of force pushed the wiper from side to side and it freed up and worked again
    Mar 2012
    23
    Thanks mate I have been told that the motor needs replacing as the water sprinkler is leaking onto the boot lock if used so mite as well change it if required
  1. Audi A6 98 Q number plate light and rear fog not working
    By MADEIRA in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th April 2012, 20:13
  2. Airbag light and noise on idle
    By jin2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2011, 21:14
  3. Airbag light and Fuel Gauge FAULT!!!
    By jetturk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2010, 08:31
  4. Few pics after coilovers and rear wiper blank!
    By steviet in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 20:53
  5. changing headlights and rear lights to facelift
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2004, 23:10
