AH FabricationsBadger5
    Jun 2012
    21
    Drivers side carpet footwell wet!!
    I have alarm bells ringing after I lifted the audi rubber carpet on the driver side to clean the car to find it wet. I had this happen to my a6 c5 back in the day and it ruined all the wiring and the ccm so I dont want to go through all that. It has not been long since as I have cleaned the car 3 weeks ago and it was dry. My initial though was something is blocked in the front windscreen scuttle area or a seal is damaged. I will tear things apart and have a look, have you guys come across this before? Passanger side is dry, it is a 06 8p if it is of any help.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    pretty common on most cars to be honest.
    perished door seals or as you say scuttle panel bunged up with rubbish.
    even the seals at the bottom of the windscreen can go and water can trickle in down behind the dash and underneath the carpet.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Will be the usual leaking around the speaker. Try this thread.....
    Drivers carpet soaked
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    bug
    Jan 2012
    71
    I've got exactly the same issue. Digging I found there is water running down the wiring loom on the right hand side of the driver side footwell every time the rear washer is operated.. Just wish I need where to go from there to fix it!
  1. Drivers footwell wet
    By s3joe in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2012, 09:21
  2. Drivers carpet soaked
    By jamessg1962 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2011, 17:35
  3. Replies: 10
    Last Post: 27th October 2010, 20:44
  4. Water in the driver side footwell
    By Kostas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2009, 18:34
  5. Driver's Footwell Picture / Footrest
    By SnAzBaZ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2008, 16:39
