Ive recently bought a Forge TWINtake and it flutters as you say when boost is built and i let off the throttle quickly. Its simply the natural noise from the turbo. The standard airbox and setup it very restrictive and also dampens noise of the car so that it appeals to people unlike enthusiasts who enjoy hearing whats going on. The TWINtake is not restrictive what so ever so it allows the engine to breath in as much air as it needs, hence you can hear the boost build up. Then when off the throttle from full boost the pressure is released obviously through the DV and noise comes back through the intake.
I would suggest uprating your DV though, ive heard the Rev D valve is much stronger than the original but depending on how much boost your running could mean you still need something stronger.
Im planning on getting to Stage 2+ in the next few months, and ill be using the Rev D DV, untill it cant handle it, but from what ive read it shouldnt have and problems.
