Monster MotorsportEM Tuning
Results 1 to 9 of 9
    kanecullen89's Avatar
    Jul 2009
    358
    Strange clutch/gearbox issues
    Hi,
    I have a strange intermittent problem with my clutch and/or gearbox.
    Yesterday after about 10 miles of driving I noticed that it was becoming quite hard to put in to gear. Mainly when stationary.
    It didn't discriminate either, gears 1-6 and reverse were all quite hard to select and had to pretty much be forced in.
    I think the reason behind this was that the clutch seemed like is was slightly engaged even when I had the pedal fully in.
    I drove the car today and it was perfectly fine again. This did happen about a month ago but I thought nothing more of it.
    The weather was quite warm and sunny yesterday and I remember from the previous occassion that the weather was hot then too.
    The clutch seems strong with no slipping so I'm at a loss.
    The car is a 55 A3 2.0 tdi non-quattro BKD with 80k on the clock and counting...
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    had a gearbox oil change recently? Might help? :-/
    has it had a new clutch on its life yet?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jul 2009
    358
    I certainly haven't changed the gearbox oil since I've owned the car and I bought it with 45k so I doubt it was done before then.
    No new clutch. Still on original.
    Could this mean that the clutch is on its was out? I though the signs were slipping clutch or when the bite is right at the top of the pedal travel?
    Jul 2009
    358
    *thought
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    well it could be the syncro but doubt it.
    well if money is tight I'd go for a gearbox oil change and see how you get on.
    but it true reality, if cash is flowing ok, it's probably new clutch time, it's done fairly well I'd say.
    antmax7's Avatar
    sheffield
    300
    Have you tried bleeding the clutch slave cylinder???
    just with you saying it happens in every gear and seems to still be engaged.
    Just a thought nice easy fix for you if it is
    Jul 2009
    358
    New clutch is deffinately an option, got a few outgoings for now though so I think that will have to go on the back burner until the mrs starts working again.
    How easy is it to bleed the clutch slave cylinder?
    Im just hoping its not the clutch gone. It's odd because it's only happened in hot weather and only twice. I've never seen these symptoms before on any other cars. Like I say, I've driven it today and it's fine again. Probably will be until its really hot again
    Jul 2009
    358
    Oh by the way, when I change the clutch, I wouldn't go for standard one. I would want an uprated clutch an remap. Any idea of pricing or them together? And good companies in the midlands area?
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by antmax7 View Post
    Thats a fair point, Check this first before you change your clutch. could potentially save you some money!
  1. Strange Clutch Slip Issue
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2012, 22:31
  2. Strange clutch issue!
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2011, 21:19
  3. Strange clutch noise
    By mikel_86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2007, 18:07
  4. Please diagnose this clutch/gearbox issue
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2007, 23:10
  5. ping Scotty - gearbox issues???
    By imported_Teutonic_Tamer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2004, 13:52
