Sky InsuranceChris Nott
Results 1 to 13 of 13
    Apr 2011
    Doncaster
    68
    Fitting steering control module without steering angle sensor
    Managed to pick up a cheap complete steering column on ebay with MFSW, cruise control stalk and steering control module. Obviously from a crashed car as everything was covered in airbag dust when it arrived.
    When I took the column to bits I noticed there was no steering angle sensor where it normally sits. Also there are no pins in the control module to accept a sensor so I assume this is off a vehicle that has the sensor as part of the electro mechanical steering assist.
    Steering Angle Sensor
    • Yes: The Steering Angle Sensor (G85) is installed directly at the Steering Wheel/Slip Ring.
    • No: The Steering Angle Sensor (G85) is part of the Electro Mechanical Steering Assist.
    I can't give the part number as someone has scratched it off (A bit weird ) but I'm just wondering what to expect if I fitted this to my car? Would it royally **** the power steering or just throw up an ESP fault?
    Tom
    2007 1.9 Audi A3 8P Sportback
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    I'd expect it to just throw an ESP light with the fault along the lines of
    "00778 - Steering Angle Sensor (G85)"
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Apr 2011
    Doncaster
    68
    Cheers, didn't want to rush in and do it if it was likely to kill my PAS till I buy the correct module.
    Tom
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    do you have the part number of the electronic control module as that would also help to say what it has? or if not what year is that steering rack from and what year car do you have?
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Apr 2011
    Doncaster
    68
    Just fitted it all everything works apart from the self centring of the wheel isn't as light as it used to be when driving. I assume that's down to the steering angle sensor being disconnected. I can live with that until I get the correct module.
    Quote Originally Posted by itwasntme187 View Post
    The steering column has 12/03 stamped into it which I assume means its from an 2003/2004 tiptronic (it has flappy paddles) model. My cars a 2007, like I say everything works apart from the steering feels a bit weird which I think the correct module with the plug for the steering angle sensor on my steering wheel (this module has the plug but doesn't have any pins inside it)
    Tom
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    hang on... is your car also a DSG? as you said it has flappy paddles.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Apr 2011
    Doncaster
    68
    No its a manual, a bit gay I know putting the flappy paddle wheel on but I won the whole lot for £28 on ebay so can't really complain.
    I've just bought a 1K0 953 549 BP module on ebay which according to this
    is a highline module compatiable with my slip ring and a MANUAL car haha
    Steering Wheel Control Module Versions - Ross-Tech Wiki
    Tom
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    mate if you want a control module to do the mfsw on an audi a3 before 2009 then you need 8P0 953 549 E or 8P0 953 549 F
    no other control module has been found that will support MFSW.
    the 1K0 modules are from golfs which support the basic steering and cruise control
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Apr 2011
    Doncaster
    68
    Ah ****, I assumed because the one I took off my car was a 1K0 953 549 AH (midline) that they were interchangeable with any 1K0 parts on that list.
    Tom
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    well dont worry, if you have the right module from the other steering rack then it should all work. do you not have VCDS? you can just run a scan on the car and find out what that module once you have it plugged in.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Apr 2011
    Doncaster
    68
    Good thinking!!
    So the module I had on the car to begin with (no MFSW or cruise) was 1K0 953 594 AH
    According to VCDS the module I've just installed which came off of a column with MFSW, cruise and flappy paddles is 8p0 953 594 K
    Tom
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    ok so that explains the lack of steering sensor... the module is from a facelift model car... 2009+
    the newer cars have the steering module built in and thus it wont properly work in your car.
    you need an F rev control module... your old steering sensor will work with the F rev controller
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Apr 2011
    Doncaster
    68
    Ahhhhh that makes sense now, thanks Ash you've got me there in the end! Haha
    Tom
  1. Steering Control Module discovery (MFSW)
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2014, 17:44
  2. A4 B6 Steering control module 8E0 953 549 S
    By Mark_Eire in forum For Sale/Wanted - Audi Parts
    Last Post: 10th April 2012, 12:34
  3. Replacing steering control module.
    By Morten88 in forum General Technical / How To
    Last Post: 5th April 2011, 00:02
  4. Vag-com, steer angle sensor, 2000 S3
    By MONKIEE in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2006, 20:01
  5. Steer Angle sensor, location
    Last Post: 14th May 2006, 18:06
