Volks AutosChris Nott
Results 1 to 13 of 13
    Jan 2012
    11
    Key Fob problem - Not locking or unlocking
    Hi there,
    I have recently changed the batteries in the key fob and tried the re-sync option in the manual (I only have 1 key) as the key fob doesn't lock or unlock my Audi A3 2.0 Tdi 2004 model.
    The key still unlocks the car when putting it in the key hole but the alarm will go off when enter the car and only goes off if I put the key in the ignition.
    I noticed you can get a used key fob off ebay but I'm unsure on the part numbers.
    Can anyone give any advice what the cheapest way to solve the problem?
    Cheers,
    Craig
    Apr 2012
    N. Wales, LL22
    1,224
    resync it using vcds
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Fossie
    Rhubarb Triangle
    3,961
    If you buy a used keyfob off ebay you will need to get a new immobiliser chip to put in it unless you only want it to lock/unlock. Even then it would need to be coded to the car.
    Presumably your existing fob used to work properly ? If so then you need to re-synch it as said above.
    The red led does flash when the button is pressed I presume ?
    Jan 2012
    11
    Cheers for the replies.
    There is no LED flashing on the fob but it did used to work.
    Do I just go to Audi or local specialist to resync using vcds?
    Cheers,
    Craig
    Fossie
    Rhubarb Triangle
    3,961
    The LED should flash quickly every time you press a button. Are you sure you have put a new battery in the correct way round ?
    You should be able to go to any VAG specialist to have it re-synchronised if necessary.
    Apr 2012
    N. Wales, LL22
    1,224
    audi will pull your pants down for that job
    find someone local in the vcds forum to do it
    VCDS in North Wales
    Jan 2012
    11
    I have tried the battery both ways. Where is the led light? I have a 3 button remote key.
    It has a code of HLO 8P0 837 231.
    I've been quoted this on ebay...
    Hi,
    Yes I can supply the correct item, with a new Canbus transponder so it is ready to be cut and programmed.
    I am after £40 including postage for the item.
    Regards
    - remotefobcentre
    Apr 2012
    N. Wales, LL22
    1,224
    ahh a no light key
    VCDS in North Wales
    Jan 2012
    11
    That's the one!
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by a3tazza View Post
    That's the one!
    Sorry - I was talking about the later shape !
    Jan 2012
    11
    I'll just get one off ebay with a new transponder, get a new key cut and reprogrammed to see if that does the trick, at least I'll have two keys then.
    Fossie
    Rhubarb Triangle
    3,961
    Before you do, may I suggest you get a quote to have it coded to your immobiliser. I think you may get a shock !
    26,777
    Dont waste your time & there are very serious security ramifications of using external parties for coding immo these days, stick with audi & also the megamos48 immo chip they use needs half programming anyway by germany to be able to do rest at dealership.
  1. key fob problems!!!! need help
    By Mcblow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd July 2010, 14:45
  2. New key fob problems
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th April 2010, 11:44
  3. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
  4. Key fob problem
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st January 2010, 20:54
  5. Key fob not working
    By S3-James in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 19:15
