Chris NottBadger5
Results 1 to 8 of 8
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Turbo Issues - loads of agro.
    Haven't posted on here for a while - been fairly busy at work and found this place too distracting so had to avoid the forum.
    Anyway having a mere of a time at the moment, sequence of events :-
    Been getting over boost codes, car has done 83K miles and tried last year to clean with Innotech which worked for a while, but started up again recently.
    So ordered a recon Turbo for the place that supplies the garage where my mate works (mechanic).
    Arrived OK and fitted it a couple of weeks ago, and a short test drive everything seems fine, couple of days later and on a longer run it flagged an under boost. Anyway after a bit of diagnostic work I found that the actuator on the Turbo that they supplied is leaking of vacuum so not holding the vanes in place. So speak to the supplier and get a replacement actuator, which we have now fitted and although this one holds a vacuum OK the car is still flagging under boost codes and going into limp mode (otherwise know in my house as as flat as a fart mode).
    No obvious boost leaks, can't hear any and the pipes all look fine, tested the vacuum run to the Turbo from the solenoid block and that is fine.
    I've emailed the supplier to see if the actuator could need adjusting and awaiting a reply. In the meantime my mate has been signed off sick for a couple of weeks and can't do any heavy work. So hoping that they don't want to replace the whole Turbo.
    So I'm off tomorrow on a business trip to North Wales in a hired Astra (or equiv).
    Does anyone have a VCDS log of a good stock BKD (2.0TDi 140 BHP) MAF and requested against actual boost ?
    Thanks.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    742
    First thing to check is the wastegate rod adjustment (as mentioned) if thats not been set to the right length it can cause issues.
    Also,
    Check the pipe work on the intake side of the turbo, you wont hear a boost leak (hiss) from this side but it will also cause you problems if there are any leaks/splits.
    Check the vac pipe from the N75 to the airbox for splits etc.
    Check the air intake (box & filter) aren't clogged.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Feb 2007
    Hampshire
    1,654
    Well interestingly just spoken to the guys at the turbo recon firm and they say that the actuator shouldn't be adjusted, as long as it went on fine it should be OK.
    I need to do some logging for them. Well at least I know how to break it.
    Paul
    VCDS HEX-USB+CAN
    max69vk's Avatar
    Apr 2012
    742
    Quote Originally Posted by Gti Jazz Blue View Post
    This is only true providing they adjusted it correctly before fitting it, even a couple of turns adjustment of the rod can make a world of difference between overboost & underboost.
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Sounds like a head f**k to me, hope you get it sorted mate.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Feb 2007
    Hampshire
    1,654
    Well my Astra turned into a Corsa 1.4 SE Automatic - the worst combination of Engine / Gearbox I have ever driven. The Astra had its hire extended at the last minute and all they had left was the Corsa, gave me a 10% discount though.
    The fun starts later with a logging session this Evening to see what is going on.
    Paul
    VCDS HEX-USB+CAN
    Feb 2007
    Hampshire
    1,654
    Thumbs up Fixed : Turbo Issues
    Well a strip down at the weekend of the boost pipes downstream from the Turbo revealed a split o-ring seal. It was the joint at the end of the solid boost pipe. Not enough to be audible, but enough under certain circumstances to trip an under boost code. So a quick trip to our local TPS for a replacement o-ring seal. (almost £5 mind).
    It has behaved since, so that is a relief.
    Paul
    VCDS HEX-USB+CAN
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    You will be glad you found the culprit eh!
    Good job.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
  1. 2007 TDI 140 possible turbo issue
    By Damo M in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2011, 17:45
  2. Newbie With S3 Turbo issues!!
    By mo_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2010, 16:17
  3. Turbo issues
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2009, 10:06
  4. Turbo issues???
    By Scottynic in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2009, 19:36
  5. Turbo Issue Questions
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th September 2004, 08:46
