EM TuningVolks Autos
Results 1 to 10 of 10
Thread: not more tyres
    GARTHY's Avatar
    Jun 2003
    230
    not more tyres
    Having checked my tyres, on my 3.2, I found the inside edge on both fronts badly worn. The primacys also had little rips in the tread blocks thro to the grooves. I have ordered 4 pzero nero for tomorrow and an alignment check. not sad to see the primacys go I must admit.
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Re: not more tyres
    Good luck with the pirreli's mine are looing decidely used after 6.5K...
    Jul 2004
    S.E. Essex
    152
    Re: not more tyres
    What's wrong with the primacys?
    GARTHY's Avatar
    Jun 2003
    230
    Re: not more tyres
    primacys lack real grip and imo never feel attached to the road. On my tq i changed to F1s and the difference was astounding in noise and grip.
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Re: not more tyres
    I had impressive inner tire wear on my fronts as well.
    I was surprised by this because I expected the outers to wear more rapidly. I had my alignement checked and it was perfectly within specs.
    It seems that the large amount of caster induces negative camber in the outside tire, which could explain the inner edges wearing faster.
    Ibis S3 Fan Club
    Jan 2005
    Somewhere Cold
    1,496
    Re: not more tyres
    [ QUOTE ]
    [/ QUOTE ]
    Yep, my fronts are wearing the inner edge quicker than the outside [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    GARTHY's Avatar
    Jun 2003
    230
    Re: not more tyres
    alignment slightly out and adjusted, lets see what happens. only done 30miles so far but initial impressions are good.
    JaminBen's Avatar
    Jan 2005
    532
    Re: not more tyres
    "good" as in more stable in a straight line?
    Do you know which dimensions were out of spec? Was there any toe-out up front? TIA
    GARTHY's Avatar
    Jun 2003
    230
    Re: not more tyres
    seem a lot more stable and precise, the steering is more direct. There was toe-in on both sides, not a huge amount but enough. The car is much quieter as well but it is still early days, the wife will drive it tomorrow if she notices a difference then there must be one.
    GARTHY's Avatar
    Jun 2003
    230
    Re: not more tyres
    tyres quieter, no yellow flashing light - thats the answer Igot. women drivers!
