Monster MotorsportChris Nott
Results 1 to 21 of 21
    Jun 2012
    Bristol, UK
    54
    Question Lights left on alert? + more questions from a new owner
    Hi, first post here.
    I've only recently got my A3 8P 2.0TDi Sport and love it already, it 54 reg.
    Are they supposed to have a headlights left on alert when you take the keys out? Almost flattened the battery they other day already!
    Also, my windows don't go up or down when holding lock/unlock on the key fob, is this standard? Do I have a fault somewhere?
    Chris
    Jan 2012
    1,601
    Take the key out with the sidelights on and open the door
    Up/down can be enabled with vcds
    Welcome to ASN
    Jun 2012
    Bristol, UK
    54
    Quote Originally Posted by A6CR View Post
    Welcome to ASN
    Thanks for the welcome.
    Hmm, I must have a problem then, left the sidelights on, took the keys out and opened the door, no alert.
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Follow Helifella On Twitter
    Welcome to the forum,
    Are you sure you have selected sidelights? The first position from 0 is for daylight running ((lights DRL's) front only, unless altered in VCDS) - these don't trigger the alert, whereas the second position will activate your sidelights (front & rear) and give a warning when left on / ignition off / door open.
    Hope this helps?
    PS DRL's will turn on/off automatically hence why no warning is given.
    PPS I did read somewhere to open all windows then close them using door switches to reset them and then try the long press on the keyfob. On my DIS I can choose whether the windows open / close via the comfort setting (keyfob).
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Jan 2012
    1,601
    This is what should happen - as you can see my car has DRL (so ignore this if you dont have them). You might have a faulty door switch or something - turn your ignition on and open your drivers door, does it display on the central screen?
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Apologies my post may not be relevent as after coming back to the thread now, I realise, as stated you may not even have the DRL's
    Sorry.
    Regards
    HeliFella
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    329
    Quote Originally Posted by t0ph0id View Post
    Chris
    My '53 has the same issue. If I open the driver door it's does not show in the dis.
    Jan 2012
    1,601
    Does it alert you if you leave the lights on?
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Chris
    Sounds like you have a faulty door switch. The car isn't knowing you've opened the door and hence no "lights on" warning. Does your interior lights come on when you open the door?
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    roblr's Avatar
    Jan 2012
    Milton Keynes
    40
    Got the same problem on my '53 also, interior lights come on when the drivers door is opened but no lights alert or anything on the dis saying the door is open, unless I open the door with the ignition on :/, still no lights alert either way
    Jun 2012
    Bristol, UK
    54
    So I checked this morning and when I open the drivers door it does not show on the DIS, when I open the passenger door it does.
    Looks like a faulty door switch then?
    Anyone know the part number and how to change it?
    Got the remote windows working, just needed to hold it down a bit longer, I was being impatient.
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    I had this problem on my old 04 plate 2.0 TDI. There were some really strange electrical things going on with it. All the lights would flash on the dash when I turned the stereo off without the keys in the ignition also... weird.
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    Apr 2011
    Mid / Northwest
    329
    My interior light does not come on when I open the driver door nor do I get the alert when Leavig the lights on.
    Where can I locate to door switch?
    Jun 2012
    Bristol, UK
    54
    Quote Originally Posted by The Engineer View Post
    Yeah my interior light doesn't come on either, only when the passenger door is opened.
    Apr 2012
    N. Wales, LL22
    1,224
    its attached to the door lock inside the door
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Jun 2012
    Bristol, UK
    54
    So anyone know the part number and how easy it is to fit?
    Is it just a case of popping the door card off and replacing the switch? Is there much disconnecting involved? Simple plug to pull out?
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
    Red ambient lighting
    Jun 2012
    Bristol, UK
    54
    Still trying to get this issue sorted, can anyone help with the part number?
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
    Fossie
    Rhubarb Triangle
    3,961
    The switch appears to be part of the door lock and is not available separately.
    The part number is dependent upon 3 door or sportback and chassis number. The earlier one is £110 and the later one £130.
    Jun 2012
    Bristol, UK
    54
    Thanks for the response Mike.
    Mine's a 54 plate 3 door sport TDi
    So if looking on eBay or parts site I'd be looking for a new drivers door lock for the same model?
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
    Fossie
    Rhubarb Triangle
    3,961
    You are looking for 'door lock with contact switch'. Early part number (up to chassis numbers 8P-5A200000 and 8P-5B050000) is :-
    4E2 837 016 (£110)
    Later part number is :- 4F2 837 016 B (£130)
    Jun 2012
    Bristol, UK
    54
    4E2 837 016 (£110)
    Amazing, thanks a lot Mike.
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
  1. A few questions from a new user, hope you all can help
    By Gavin G in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2011, 09:50
  2. A few questions from a new owner
    By Cardiff R33 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2011, 15:39
  3. Can Bus Question from vcds new boy
    By rjm180 in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th July 2010, 13:24
  4. Replies: 3
    Last Post: 4th August 2009, 11:10
  5. Question from a new guy
    By jetspeed in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2004, 09:21
