EM TuningAH Fabrications
Results 1 to 10 of 10
    Jun 2012
    11
    AUX connection will this fit?
    Guys
    I seen this on ebay..
    Audi A2 A3 A4 TT aux input 3.5mm jack lead car radio iPod MP3 adapter CT29AU04 | eBay
    I know its probably been covered but couldnt find anything quickly... I just need to know if this connection will fit my concert 2 single din cd player. Will it just use the CDC connection on the back? isit a quadlock?
    Thanks for your time guys
    Fossie
    Rhubarb Triangle
    3,969
    Does your Concert radio have an 'AUX' button on it ?
    Jun 2012
    11
    No it does have the cd changer though, is this how this is connected?
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    337
    Cheaper one here:
    CT29AU04 Audi A2 A3 A4 TT Direct Auxiliary Input Interface with Free CT29AX01 | eBay
    looks like it would fit this (back of double din Chorus II+):
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    I think you may have to disconnect the CD changer connector & fit this in its place - don't you have the 'Aux' socket down by the cigarette lighter then?
    2009 A3 SB 2.0T DSG S line
    Apr 2011
    Doncaster
    68
    Yes that'll clip into your quadlock harness and then plug into the back of your headunit. To get into the aux mode press the "CD" button twice, if nothing happens then you'll need VCDS to code it.
    Tom
    2007 1.9 Audi A3 8P Sportback
    Apr 2011
    Doncaster
    68
    Oh hang on you said yours is a single din? From what I know the single dins don't have a quadlock and the link you've put up is to fit a quadlock unit
    Tom
    Apr 2011
    Mid / Northwest
    337
    Quote Originally Posted by Pricy View Post
    This is good to know. I'm going to try it for that price.
    Thanks pricy
    27,114
    No, the single din does not support auxin directly, needs an intelligent device plugged in via the chnager connection afaik, quadlock units do have a direct auxin compatibility.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    single din does not have quadlock.. agreed
    get a dension gateway or something.. the gateway control/box dupes the head unit into thinking there is a cd changed connected. Thus, you only ever need to press the CD button to switch between CD and CD changer mode aka ipod connection. There are two versions available... one with no DIS support and one with DIS support. You can control your music from the head unit.
    Check the dension website to see which one you need... I had mine installed by andymac... no probs to date... well has frozen once but pretty straight forward to re-set
  1. Will this fit my S3?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2006, 18:43
  2. will this fit
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2006, 19:44
  3. Will this fit my car???
    By killa_z in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2006, 00:08
  4. Will this fit a 2002 A4 1.9TDi?
    By necroeire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2006, 13:38
  5. Will this fit into the S3 dash if i buy it?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2005, 08:35
