Volks AutosJMB Retrofits
Results 1 to 9 of 9
    Apr 2012
    25
    A3 brake pad sensor
    Right just changed the rear pads and dics on my a3 but couldn't see we're the plug goes for the brake pad sensor spoke to the shop were I got them and they said there may not have them on the back so cut it off but the light is still on the previous owner changed the front pads and cut the sensor on the front passenger side an twisted the connection to form a loop so is there one on the back as the light on the dash is still on anyone know we're this is??
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    If you didn't need to take a plug out with the old pads you shouldn't need to plug the new ones in anywhere surely?
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Jul 2010
    561
    I didn't think the rears had a sensor?
    Apr 2012
    25
    Well they had one on but the light on the dash is still on an cant figure out why
    27,094
    With all respect, if you unplugged the old ones, then I cant see how you cant plug in the new ones.
    Apr 2012
    25
    As I said the new ones had a sensor wire but the old had none so just assumed that they should have them the issue I have is the light is still on
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    No offense but if you are this unfamiliar with brake systems you shouldn't be touching them.
    Put it into a garage to get done.
    Sounds like there is a problem with the fronts still.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    27,094
    Quote Originally Posted by Stevo11 View Post
    With all respect mate, thats not what you said, you advised us you couldnt see where to plug them in, not, the old ones didnt have plugs, but alas.
    You need to plug vcds or the like in to ascertain where the light is coming from, whereabouts are you located?
    Apr 2012
    25
    Am in the clitheroe area
  1. brake pad sensor light
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2012, 22:38
  2. Brembo brakes and brake pad sensors...
    By imported_MattT in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2011, 07:48
  3. brake pad sensors
    By stu_m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th November 2010, 13:56
  4. Replies: 15
    Last Post: 27th May 2008, 20:41
  5. damaged brake pad sensor
    By beerglass in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2006, 15:55
