Results 1 to 13 of 13
    Jun 2012
    11
    Upgrade to the speedo section?
    Guys,
    bought my 8p few days ago and im a little disappointed that the LCD in the speedo is missing. I used to own a 2003 TT and it had a LCD display that showed MPG reading, temp, doors open, milage left, warnings ect...
    Any one swapped this on their A3 , how easy isit?
    Jan 2012
    1,615
    Been covered a million times over on here - do a quick search
    But yes, it's easy.
    Jun 2012
    11
    Thanks for the reply, so ive done some reading and see what i want to do is mod the DIS.
    I currently have the standard black box that displays icons only, no LCD module is installed... So from what i have read i need...
    • New cluster and instruments
    • New stalk with controls
    • Coded to allow DIS to work
    My questions are , how easy isit if i buy a cluster and instruments with more milage on there? Isit easy to modify? , Is the coding easy? Can Audi do this for me? if so anyone been quoted?
    26,774
    Best bet is to fit the newer white dis version, I can offer this service in Sussex, whereabouts are you located as had numerous people come down to do it & no you cant do yourself as immo needs coding aswell as mileage correction.
    Jun 2012
    11
    In Glasgow mate,
    What sort of cash are we talking for this install including parts?
    26,774
    What year A3?
    Kelvin_S's Avatar
    Apr 2012
    Bristol
    237
    £700+
    To do:
    MY11/ S3 Chrome mirrors /Springs / 20" Alloys / Wrap
    Dream plate: B055 KKS One day.
    Jun 2012
    11
    wow! , 700 to add DIS...
    Its a 2006 SE 3 door.
    26,774
    £700+ is for a brand new cluster, as you have an 06, the fuel pump is fine for the newer dis, I've done it for less than that for number of members.
    Which engine is yours?
    Jun 2012
    11
    Hi thanks for your reply, my engine is just the standard 1.6
    I found a cluster on ebay for a 2007 tdi 2.0 which has 30k miles on it. Mines has 29600. Was thinking i could use this to replace my current cluster and i wouldnt even need to change milage?
    Then i just need a stalk and coding... am i right?
    26,774
    You need immo programming by a dealer, its not a simple stalk & coding as such, you must get the immo coded with all keys & documents by a dealer, also as yours is an fsi then you need to make sure the speedo & rev counter match, if not, then its no good to you, plus the white dis version is far better.
    I think have an older red dis cluster for an fsi 1.6.
    Jun 2012
    11
    yea the cluster i seen is a complete match regarding speedo and rev counter. The milage is basically a match aswell..
    How much is the coding on the immo from Audi?
    Trying to weigh up this to see if its actually worth it.. £700 for temp, mpg and miles to empty is a bit steep i think. So if i can do most of it myself then have the coding done then it might be worth while
    26,774
    I already advised you its several hundred less than £700.
    Depends on your local dealer, thats upto you to ask, as we cant answer, I can only advise what I can get it done for.
  1. wheres the rant section????
    By silver75 in forum Site Support & Announcements
    Last Post: 6th September 2006, 19:13
  2. Just posted this in the A8 Section - WOW...
    By hop2407 in forum General Chat
    Last Post: 14th September 2005, 07:02
  3. Clutch upgrade - ECS the favourite choice ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2005, 14:28
  4. Did Audi do a 250bhp upgrade for the S3?
    By S2KI in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2004, 11:40
  5. Disc & Pad Upgrades for the 3.2?
    By imported_JON_XL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2004, 01:15
