Chris NottVolks Autos
Results 1 to 12 of 12
    PaulS3's Avatar
    UK
    1,003
    TPMS Via the DIS VCDS Mod
    Hi has anyone managed to get this enabled via VCDS with the DIS.
    I have trawled the net including this site, and have found loads of information for the switch version retrofit, and the version where VCDS is used to reset the system, but no reference to enabling the later system settable through the the DIS.
    I have a MY11 S3. with the 1AT ABS unit which suggests "ESP ready for TMPS and Hill Hold "
    If its just a matter of 10 minutes with VCDS then it would be rude not to.
    Audi S3 Quattro Black Edition.
    27,013
    You will only know when you try to code the options, if your cluster/abs controller supports it.
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,423
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    I tried to do this a few weeks back and got everything working apart from the DIS control (Even though I got it on the DIS)
    TPMS - A3 2012 - Coding Issues? VCDS users please check!
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
    PaulS3's Avatar
    UK
    1,003
    Thanks. I have posted a reply in your thread which may help explain your issues.
    Jul 2012
    Cheshire/N Staffs
    1,245
    Same here. MY2011 S3.
    Thought I'd try various permutations of the coding to get TPMS via DIS to work, but no joy so far.
    My ABS module: 1K0 907 379 AT
    My Kombi: 8P0 920 982 L
    Tried:
    In the ABS coding, Byte 16 for 7K6
    Byte 17 for TPMS via DIS options
    Tried various combinations of these two options
    In the Kombi coding, adding +16 to ????xxx
    Adaptation in Ch.37 x?xx
    Still drawing a blank. Really need a MY2010/MY2011 car to scan, to see what the coding/config is!
    Anyone?
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    27,013
    The 379AT unit supersedes to a 375AT which then supersedes to a 375BE that does support this feature 7K6, problem is, this doesnt denote the previous AT versions support all the functions of the BE, vag have a habit of doing this where if a module needs replacing for whatever reason, they fit the newer module, maybe the all in one/highline version, that supports everything, thus they only make the one module type then on.
    It may need vas or odis to code this properly if there are missing data from vcds, ideally need a car that has the option already & compare coding, modules fitted & adaptation channels.
    PaulS3's Avatar
    UK
    1,003
    As per my reply to Cruisers other post linked above,
    Indications currently point to the requirement for the 4C: Tire Pressure II module.
    The forums I have linked to have logs of cars fitted with TMPS indirect and they seem to have the 4C module which we seem to lack. Perhaps this is where the circumference values are stored/compared hence why they cannot be saved?
    If its going to be more than a simple VCDS procedure, I can live without it.
    27,013
    The TT has a tpms specific unit which wires to the cluster, abs controller, button in gear surround area, which maybe because the abs controller doesnt support tpms directly, but there are no mentions in schematics for the 8p in my12 for a tpms specific module or in etka, so atm its not likely this.
    PaulS3's Avatar
    UK
    1,003
    For reference, mines has a 1K0 907 379 BE ABS module.
    27,013
    & that also supersedes to the 375BE these days.
    That info has helped me thanks, as I have that module new to fit to my car for tesing, can you fire over some logs if possible please if I need to do some research?
    PaulS3's Avatar
    UK
    1,003
    Thanks, good to know, maybe it is possible after all. Perhaps its just the method/module revisons.
    Yes happy to send a recent log. What info do you require? Part or full log?
    PM me an email?
    PaulS3's Avatar
    UK
    1,003
    To close out my own post, Successful TPMS via the DIS is discussed and covered in this thread
  1. MPG on the DIS
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th February 2006, 15:04
  2. Do you lose the DIS with aftermarket HU?
    By ImS3ola in forum In-Car Entertainment
    Last Post: 29th October 2005, 22:46
  3. Recalibrating the DIS
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2004, 12:29
  4. The ultimate TDI mod
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2004, 12:26
  5. Extending the warranty with mods
    By Dylarolla in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2003, 09:19
