Chris NottMonster Motorsport
Results 1 to 7 of 7
    bug
    Jan 2012
    71
    Water Leak in Driver Side Footwell
    Hi Chaps,
    Help much appreciated!
    Got bucket loads of water pooling in my driver side footwell. I keep sucking it up with the vacuum but it comes back quickly. It doesn't really have any smell to it, I'm sure it's not coolant as I've been keeping an eye on the level.
    If anyone can suggest anything to me, it'd be much appreciated. Did a search but not much was returned.
    Cheers!
    bug
    Jan 2012
    71
    Its a 53 plate 140 tdi if that makes any difference..
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,619
    either door seals or make sure theres no leaves in the part underneath the windscreen where the drain holes are, they need to be clear.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    You need to remove the scuttle panel, clean all the debris out and make sure the drainage channels are clear. Also make sure the seal at the bottom of the window screen hasnt perished.
    Dan
    bug
    Jan 2012
    71
    Cheers for both your inputs! I'll remove the scuttle and take it from there.. Could it be anything to do with the rear washer pipe?
    bug
    Jan 2012
    71
    Please Help!
    Done further digging, removed the scuttle, driver wheel arch and driver footwell carpets.
    All I can see is water running down the wiring loom on the right hand side of the driver footwell. Every time the rear washer is operated a huge amount of water gushes down the wiring loom and into the footwell. The rear washer still operates with good pressure.
    It looks as though it must be at the top back of the dash..? I hoped removing the scuttle would show me the problem but I was left non the wiser.
    Someone please help me, I'm well and truly stuck!!
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    here is a thread that roughly had the same symptons as you
    Water in footwell + rear washer jet not working + aircon knackered
    skip down to the bottom
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
  1. water leaking in the passenger footwell
    By stimpy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th January 2011, 22:28
  2. Replies: 10
    Last Post: 27th October 2010, 20:44
  3. Water leak / dripping in passenger footwell when AC is on
    By Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2010, 21:10
  4. Water in the driver side footwell
    By Kostas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2009, 18:34
  5. Water Leak on Drivers Side
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2004, 07:20
Tags for this Thread
