Got the same unit waiting to go in, if your doing it, i recommend going the whole way and gettin the new facelift buttons MY09+ .. You'l need..
- Double din cage
- Facelift buttons, esp, blanks, passenger airbag, and card tray, or MY11 come as one peoce
- Button trim, not needed with MY11
- Doubledin climate, has to be ECON version if the cars under 57 plate
.. Ive got everything at home waiting, really is the best upgrade to interior, goodluck mate
To clarify. I need the double din climate, but I need to get an earlier one not the facelift?
you can cut down your old one to fit if you want
Lets make that 3..
Is this the right unit? If not, what is the correct part number for the pre facelift double din climate?
Audi A3 / S3 Double DIN Climate Control Air Con HVAC 8P0 820 043 USED | eBay
Thank you.
Two more questions:
1. Does the new RNS-E have a problem with battery draining when fitted to a pre facelift 8P2 or is it just plug and play?
I know MK5 golfs have this problem when fitted with MK6 navs or RCD310/RCD510s. Need to update the 'canbus gateway'? as well.
2. Did a quick search but cant seem to find any in depth info on trimming down my existing unit. Obviously it needs to be done a certain way. Is there any threads on this?
1: No, but needs coding
2: Just make up a cardboard template to fit inside the gap lower down, its about 6-8mm trimmed each side with a slight curve in middle
